truck improvement idea
Discussion in 'The Garage' started by big d, Jul 21, 2002.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    i noticed when i had my top off alittle while back some crumbley surface rust on top of the bed rails (probabley normal for a 79'), and it got me to thinking(i do that some times /forums/images/icons/shocked.gif /forums/images/icons/laugh.gif /forums/images/icons/grin.gif /forums/images/icons/tongue.gif )why couldnt a person pick up some plastic bed rail caps/protectors like the newer pickups have and drill em' for the topper mount holes and put em' on a blazer ? /forums/images/icons/confused.gif i think it would look sharp,clean up the area and protect at the same time. as long as a person cleaned up any x-cessive rust or problem areas id think it would work and i plan to do so soon. hope this helps others. /forums/images/icons/grin.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    sounds like a great idea to me As long as there not to thick to make the topper bolts to short. but it would really dress up the truck with it off.
  3. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    I'm going to do that, but with al dimondplate ones. Just make sure you have a good coat of paint below or it will be rust city.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    If your going to use diamond plate rails, you will want to make sure that the seal on your top is in good order or it won't seal against the raised diamond pattern on the aluminum diamond plate.
  5. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    I should have been more clear. The '73 has no top or doors!
  6. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    Then the possibilites are endless /forums/images/icons/cool.gif
