Truck is broken.
Discussion in 'The Garage' started by crazyrc, Apr 19, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Stepped into it a little too much today on the way to a trail. U joint stayed intact and the yoke ripped apart. /forums/images/graemlins/mad.gif Before I could get stopped the case on the tranny split.
    Guess I'll be swapping in a 400 and 205 sooner than expected. Will my front driveshaft and original crossmember still work.
    Oh yeah I'll get you guys some breakage pics asap.
  2. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    If I am correct, the cross member and front drive shaft are subject to change with the different T-cases. What t-case/tranny broke. If they are the same than it will work. Give us some info on what actually broke.
  3. crazyrc
    Jan 20, 2003
    106
    I was running a built 700R4 and 208. The ears on the driveshaft let go and I'm assuming the whipping action of the shaft caused the case to split on my tranny. It split about one inch in front of the t-case. I knew the 700 wouldn't last forever with the new engine, but I was hoping to get more life out of it than I did. /forums/images/graemlins/frown.gif
