truck keeps running?
Discussion in 'The Garage' started by jeff l, Oct 23, 2006.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    after i turn it off. Its a 79 rebuilt 350 w/600 cfm eld/carb.
    one person said that i have it idled to high. just wanted a 2nd opinoin
    thanks
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i think its called deiseling, it could be a few things like timing and idle speed. check those.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Some vehicles were equipped from the factory with what they called an "Idle stop solenoid".
    You can get them at the auto parts store. If worst comes to worst, you can installl one of them. I believe holley sells a bracket just for it too.
    But, yeah, check your timing, idle speed, choke setting...etc.
  4. matneyr
    matneyr Registered Member
    Jun 25, 2005
    20
    Blacksburg, Virginia
    I have a '85 Suburban that is notorious for dieseling. I've tried everything to make it stop, including timing, plugs, idle speed, choke -- it still does it. It's worse the closer to sea level you get.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Weather makes a difference . But for the most part idle speed . I have a Q-jet and an auto trans , I idle at 500-550 in gear , 600-650 at idle , and once in awhile it still does it .
  6. xpndbl3
    xpndbl3 1/2 ton status
    Jul 30, 2005
    510
    orland park, IL
    if you want to prevent dieseling then shut it off in gear and then put it in park afterwards.
  7. jeff l
    Jun 13, 2006
    104
    New Orleans
    thanks for all the replies. I feel better about what direction to go to fix the problem. also thanks for the kill it in gear tip. I will do that, till the week end when i get to work on it.
  8. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Carbon buildup can cause dieseling as well. Seafoam is the fix for that.
  9. ftcjimmy
    ftcjimmy Registered Member
    Mar 9, 2005
    61
    ct
    It is because theres carbon build up, the carbon gets hot spots wich ignites the compressed gasses. Also maybe you used some bad gas?
  10. matneyr
    Jun 25, 2005
    20
    Well, the stopping while in gear thing works -- but my truck doesen't diesel every time I turn off the engine, only occasionally.
  11. 02turbogixxer
    02turbogixxer Registered Member
    Aug 1, 2006
    63
    Dallas, TX
    I've tried that and it doesn't always work.
  12. 1977k5
    May 26, 2003
    9,992
    130
    That is a cover for a slightly bigger problem. Leaving the truck in gear (or in park) is not the solution to a dieseling problem.
  13. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    My uncle once told that if the engine is dieseling, it can be cured by spraying water to intake. First take off the aircleaner, then use spraybottle (one that is used to spray flowers), keep rpm's between 1500-2000 and lightly spray water to carb. It sounds nasty, but works.
    edit/ That is, when carbon build-up is causing dieseling.
  14. BURBicon
    BURBicon Registered Member
    Dec 11, 2004
    78
    Sunny Phoenix
    I've been doing the "shut it off in drive" deal for years. I'm not even sure if my truck diesels any more.
    NOTE TO SELF: Put tranny in park just to see if truck diesels next time I shut it off.
  15. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    Dieseling can be caused by alot of junk. High coolant temp is one cause I've heard and not seen mentioned yet.
    My truck does it if I put crappy gas in it. I hold the brake and turn it off. Don't know why, but it seems to work. Maybe it's just the thought of trying to do something that makes it seem to work...I don't know.
  16. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i used to have an 85 blazer that dieseled after shutoff when the engine was good and warm. seafoam cured this problem. it also idled A TON smoother and quieter.
