Truck LEANS...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ArrowheadK5, Jan 10, 2002.
  1. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    I just (?!) noticed that my truck sits a little crooked. I thought it was just my weird driveway, but now I see the bumper is not parallel with the front axle. It's dark right now, so I didn't get a real good look, but there was nothing obviously wrong. Any ideas? Broken spring? any insight welcome.
    "They couldn't hit an elephant at this dist..."
    - General John Sedgwick (1813-1864), last words
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    how far off does it look, if it is a little do you have a spare and is it on the same side that is leaning to??????? just my 2 cents hope that it helps-mike
  3. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Yeah, have a spare: it's leaning on a tree about 20 ft away! [​IMG]
    I probly should mention this is an 87 k20.
    Could a spare really make your truck lean?
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Check your spring bushings and shackles. My spring bushings are shot (again) and the truck leans to the right now...plus I believe that the frame is bent slightly, that doesn't help. Also, you sure you don't have a low tire??
  5. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    i'm not sure if anyone mentioned this but what about body mounts? they can wear out and smash into soft pieces of rubber. Check those. Check the leaves in your spring packs. air pressure. Gotta eliminate every easy thing before you find out its your frame.
    That's just my two cents. I don't know nothing.
    juan prescott valley,AZ
    chrome sucks
  6. ArrowheadK5
    Aug 3, 2001
    252
    Northern MN
    Sorry, could you define spring shackles? Are they the "strap" looking things that wrap around?
    Thanks, still learnin'!
  7. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the shackles are the two pieces of metal that are on either side of either end of the spring. they are what the bolt goes through at either end of the spring to there is four all together. two front two rear.
    and dont worry if the axle isnt level with the frame i doubt its a low tire. unless it was flat
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
    <P ID="edit"><FONT class="small">Edited by TorkDSR on 01/11/02 12:29 AM.</FONT></P>
