Truck powered out!??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TWISTEDJACK, Sep 3, 2002.
  1. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I was on an obstical similar to the dump bump and tried to ease up it but the truck wouldn't move as soon as I started the climb. I have a 350/400/205/4.10/35" combo. It wasn't a fuel problem because I have a Holley projection. Do I need deeper gears or what? I know a doubler would be nice
    but I don't have the $$$ for that right now. /forums/images/icons/frown.gif /forums/images/icons/frown.gif
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    didya have it in 4 low ? and was the face vertical ?
  3. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Yeah, is was in low, the face was vertical. The only way to get up it was to back up a foot and then hit it. When I
    got it moving it climbed up the rock face. Scared the crap out of my spotter!!
  4. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Do I need lower gears or more grunt under the hood?
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I see that you have an auto tranny. When my cousin and her boy friend came down to go wheeling with us in the dunes, his dodge wouldnt pick up enough tranny fluid to engage sometimes on extreme angles. It would work fine once we got it back on level ground. Maybe this is what happened to you.
  6. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Possible, Like my auto for being able to ease over obsticals but after this weekend, I almost pulled it out
    and put in the 4 speed I have laying around. /forums/images/icons/confused.gif
  7. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Get a SM465... gotta love the low gear ... 6.55 to one... wiht 4.56 in mine i have a crawl ratio of 77.8 or so.
    Its a good tranny, real strong and alot better than a 400 unless ya cant drive stick too well /forums/images/icons/grin.gif
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I don't think it's the auto specifically causing your problem. I have a very similar setup but your over-all crawl ratio is a little bit better than mine due to tire size. Mine bogs a bit too on some stuff like that and I have to bump it, but, usually I get tire spin before bogging down. In fact, I just did "dump bump" last weekend and had to bump just a tinny bit. Not because it bogged, but because my TSLs are not cut and slip on the slick-rock a bit. My rig has gotten lighter and even with only 7 lbs of air my TSLs are still pretty stiff. Could it be that your converter is not letting the engine get into it's torque range? My diesel converter stalls VERY low (someone said 600 rpm but I'm guessing a bit higher) and that causes some small problems getting over vertical stuff like water falls and such. Never had a problem not picking up fluid when at or near vertical or even laid on the side. Lower gears (BTW Rob, if your reading this, I hate you… /forums/images/icons/wink.gif ) with a doubler would be just the ticket. I would not go manual, but that's just me. There are trade-offs both ways and for me the auto wins the contest easily.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You found a decent trail in Idaho? Where? /forums/images/icons/shocked.gif
  10. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    Hey Sandman, I found a trail near Silver City, Short rocky
    creek bottom, tight turns but a a large rock pile at the top with a verticle face /forums/images/icons/cool.gif We have plenty of rock runs around here, tight rocky canyons and stuff. I will send you some pics later. As for the tranny problem /forums/images/icons/confused.gif
    Should I get a stall converter or just wait and get a doubler??????
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    in the long run, a stall converter, doubler and gears... but the least expensive way is the stall converter. easiest way is gears, if you can do them yourself... and then the doubler..
    grant
