Truck runs like a pos all the sudden...*FIXED*
Discussion in 'The Garage' started by hi pinion, Nov 19, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ok, up until 2 days ago,,,, i was thinking wow my truck runs great!!!2 days ago, i would try to start it, it would run good/better at high idle, and just die /forums/images/graemlins/dunno.gif Now, i try to start it and it just dies, unless i feather the gas , and even when i do have the gas held down pretty good, it still crappy. Ive already checked the gas pump, and the feul filter. There is gas spewing from the line and the filter looks new still.I even took it out and ran withought a filter.....still the same. /forums/images/graemlins/dunno.gifI checked all around the engine ,i cant see anything off the ordinary. /forums/images/graemlins/dunno.gif I dont know wtf is going on with the thing. /forums/images/graemlins/dunno.gif Do carberators just "go bad" after a while?? Just one day crap out????? It was like one day it was running, and the next day it was crapping out /forums/images/graemlins/dunno.gif HELP!!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gifJacob
  2. hi pinion
    Sep 25, 2003
    5,354
    Re: Truck runs like a pos all the sudden
    Oh yeah its an 85 blazer /forums/images/graemlins/thumb.gif
  3. cheyennesuper
    cheyennesuper Registered Member
    Nov 2, 2004
    52
    Wisconsin
    Check to see if your points are still good...
    and maybe timing?
  4. hi pinion
    Sep 25, 2003
    5,354
    How do i check that? /forums/images/graemlins/tongue.gif Pop the d cap and the what? /forums/images/graemlins/thumb.gif
  5. cheyennesuper
    Nov 2, 2004
    52
    Wisconsin
    Yeah...the point are under the rotar.just look at the head on the point and see if its fried.It could be the condenser too.You should actually see if your getting good spark before you do all that
  6. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Pop the cap and look under it for damage, burned contacts, etc. Cheap so buy and change either way. If its not the fuel pump, i'd suspect the choke on carb or the distributor coil.
    jakeslim
  7. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] Is this what you are saying...= check the heads on the POINTS under the d cap check to see if they are fried" ??? Also.....the condenser???? Where is that?? /forums/images/graemlins/thumb.gif
  8. hi pinion
    Sep 25, 2003
    5,354
    jakeslim
    [/ QUOTE ] Do carbs just crap out all the sudden like that??? /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
  9. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    I'd change the dist. coil first, if it doesn't fix it, take it back and get a refund, but change the cap too.
    I don't know about the carb though. Have ya changed the plugs lately?
    jakeslim
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well the carb could have something in it stuck . I swear to god somehow my original carb was sucking the old broken up bits of Charcoal from the cannister into the bowl vent , and it ran like you just described . I replaced my can with an older one and redid my hoses . I chit you not , pulled top off original carb and there were little specs of the black stuff in it /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  11. hi pinion
    Sep 25, 2003
    5,354
    So it ran great after that??? And you DIDDNT rebuild the carb?? BTW, when we put the carb in for the first time, it backfired a few times. Mabey that blew something up. But it ran fine(just fine to not great) for 3 yrs. /forums/images/graemlins/thumb.gif So i got the d-cap. and another peice that goes on the distributer, that has electrical plug ins on it, ill try that tommorow, and see what happens.Anyone who thinks they might have any ideas, please post it. /forums/images/graemlins/thumb.gifJacob /forums/images/graemlins/thumb.gif
  12. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just took the carb off at the parking lot at the lake and removed top , tipped over and blew out with cleaner . Did that a couple times before I found out it was from cannister and not tank or filter . I still have that carb , but its going on the project . I also forgot to mention I cut a piece of window screen and shoved in the hose before I put the hose on , just incase so crap would never get in the carb again /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  13. hi pinion
    Sep 25, 2003
    5,354
    Ok so did it run good after that?? /forums/images/graemlins/thumb.gif
  14. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Aside from the leaky throttle shafts , yes . It was one of those never would of thought it thangs /forums/images/graemlins/thumb.gif
  15. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    1) you shouldnt have point in a 85 blazer.
    2) what have you done lattly to it?
    3) see if the distributor is loose.
    4) floats inside the carb get fuel soaked and dont float but that is not something that just happens its kind of a slow gradual go bad thing.
    5) what carb is it? if it is a q jet are you refering to the filter at the inlet of the carb? that will give you strange performance.
    give more info /forums/images/graemlins/laugh.gif
    /forums/images/graemlins/burb.gif
  16. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    check to make sure your choke hasnt stuck as well mine is wired open and tuned to a nats buttocks and is only a tiny bit hard to start in the cold
    willow /forums/images/graemlins/waytogo.gif
  17. hi pinion
    Sep 25, 2003
    5,354
    #1 got a new d cap and another peice. (electrical plug in deal,has some grease pack that came with it, and mounts to the bottom of the distibuter,2 screws)..#2i havent done anything lately to it. #3distributer is tight already checked. #4i dont know#5i already ran it with and withought the flter, i get the same thing. /forums/images/graemlins/thumb.gif I dont know what the hells the matter with the thing. /forums/images/graemlins/thumb.gif
  18. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    You might have some water in the fuel--I made the mistake of filling one of my trucks with my gas can for the lawnmower that had a quart of condensed water in it from sitting outside when my truck ran out of gas in my yard the other day--now mine runs like a POS all of a sudden too--and it was self inflicted! /forums/images/graemlins/angryfire.gif.I put 3 bottles of isopropanol dry-gas in it,and five more gallons of gas--now its running ok again.Does this truck sit a lot without being driven often??--if so,water in the gas is a good possibility,and gas goes stale pretty fast nowadays too.We have been plauged by bad gas around here lately--we cant tell if we are buying it at the pumps or what--but most of the vehicles I have pulled the gas tank out of to either fix the fuel pump or junk the car,has a lot of water in the bottom of the tank.Seems the higher the price,the poorer the fuel quality lately. /forums/images/graemlins/crazy.gif
  19. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Thank you....I could not believe how long the discussion about points in an '85 Blazer went on.... /forums/images/graemlins/screwy.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/screwy.gif
  20. whiskey bent
    whiskey bent Registered Member
    May 24, 2004
    49
    Alabama
    Same thing happend to a friends 85' K10 once, this makes the first person I've heard of it happening to besides him.
