truck runs like butt all of a sudden???
Discussion in 'The Garage' started by ilikeitloud, May 22, 2005.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    drivin down the highway today just fine and then when i get off at the exit and pull upto the stop sign it gurgled down and went dead. i start it up and now it wont even idle and just dies. if i keep givin it gas she runs but sounds like its missin a ton and a high speed she seems to be runnin good. what could be the cause?? :confused:
  2. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Carbed for FI?? If its carbed it could be vapor lock.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If it is fuel injected mine did that when I had an injector stick open and it basically flooded at low RPM and ran fine up high.
  4. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    Sounds like a fuel pump to me.....if it won't idle but runs fine when at higher RPM.
    Fuel related at least, maybe clogged filter....
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    huh?
    fuel pump would be the other way around
  6. dhcomp
    Mar 17, 2001
    9,862
    296
    Truckee, CA
    Really? Then im totally off base then. Sorry.
    Fuel filter could still be a possiblitly though, right?
  7. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If its carb'd, I would guess stuck float in the up position, flooding it at low rpm, but rev it up and it starts to clear its throat. TAP, not beat on the carb by the fuel inlet to maybe unstick the float. WHOOPS- I mean stuck in the down position so fuel keeps flowing into the carb. Is there a strong gas smell, or a puddle of gas round the carb?
