truck shakes at higher speed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Sep 4, 2000.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    my trucks front end started to shake at like 70 mph and i have no idea why besides maybe the berrings but i just got new ones so i dunno if u can help please do .......thanks
  2. Mud Bath
    Mud Bath Registered Member
    Aug 28, 2000
    84
    Wake Forest NC
    you might have a bent rim
  3. DaveBlazer
    DaveBlazer Registered Member
    Jun 30, 2000
    36
    Northwest Indiana
    have your tires balanced and make sure your lugs are all snugged down, one may have been missed when the bearings were done. When you have your tires balanced ask the mech if he noticed anything like one tire didn't balance right. A bent rim, mud on the rim or a broken raidel belt in the tire can cause it.
    Good luck
    Dave
    [​IMG] BLAZER FEVER!! ITS CONTAGIOUS. [​IMG]
    <font color=yellow> 88 </font color=yellow><font color=black>K5<font color=black>
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    take one thing at a time....start from the outside in.
    check the lugs. then go for the tire balance. next the tires and rim. then check your rotor, axle (but usually these will cause vibrations at all speeds).
    Knife.
    knife.coloradok5.com
  5. Casey 86K5
    Casey 86K5 1/2 ton status
    119
    Brownsburg, Indiana
    my Camaro had a similar problem a while back and I checked everything in the front end and it was all good, it turned out to be a U-joint. I never thought that a bad u-joint could cause a front end vibration but after I got both of them replaced the vibration went away. Just my two lincolns..
    Casey86K5
  6. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Ha ha, my sister's Jeep has the same problem, it was in a wreck a few months ago, and still isn't fixed. I think the insurance co of the person that hit her is going to buy it. When you hit like 65, it starts to rattle really bad. They have had tons of people look at it, including 2 dealerships. They have also put on 4 new Good Year Tires and had them balanced 2 times. Either it isn't the same problem or they don't know anything, I will print this post out for my dad.
    Dawson
    88 K5
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    That happened to mine not to long ago and it was a u joint.
    90K5
  8. 76chevy
    76chevy 1/2 ton status
    Aug 16, 2000
    246
    Utah
    Check your rear driveshaft. It may be loose where the yoke is. It will probably feel tight. If so put the transfer case and transmision in nuetral and then give it a shake. If it wiggles you need your driveline rebuilt.
