truck shutters
Discussion in 'The Garage' started by CenTxk5blazer, Aug 23, 2004.
  1. CenTxk5blazer
    CenTxk5blazer Registered Member
    Oct 19, 2002
    90
    Fort Worth, Texas
    Last night my truck began to shutter (whole thing shakes real bad). Its done this before while I was towing a trailer but only when the truck was beginning to move. I drove it in all gears to see if it continued and it would do it again at approximately the same time. I haven't hooked up a tach to completely rule out the driveshaft, could it be the tranny or axle? /forums/images/graemlins/confused.gif
  2. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Tranny mount?....mine shuddered on takeoff...pretty much went away after I got goin..
  3. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    It seems to go away after I get going and seems to occur when it shifts but not completely. I'll replace the tranny mount to see if that fixes it.
  4. CenTxk5blazer
    Oct 19, 2002
    90
    Fort Worth, Texas
    I crawled under the truck this afternoon and checked the
    tranny mounts and u joints. Both seemed okay, but I'll still probably replace the tranny mounts. Is there anything else that might cause the truck to shake as described above?
  5. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    not to sound insulting but is your trany really low?
    and onl 2 wd truck i had did this when i did not hook up my cooler lines up tight enuff and emptyed my trans, would shake on shifts and cruseing. /forums/images/graemlins/dunno.gif
