Truck springs in a Blazer???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by vdubbin86, Jul 10, 2002.
  1. vdubbin86
    vdubbin86 Registered Member
    May 25, 2002
    55
    Alberta, Canada
    Would a set of springs from a truck work in a Blazer? If not, why?
    Just trying to figure something out. Thanks
  2. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    How about suburban Springs???
  3. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    As long as they are out of an 1/2 ton P/U,they should fit.Bring a tape measure and the K/5's are 52".3/4 tons springs(MOST) were 56".....great for some extra flex(but you have to move the rear shackle mounts.
  4. vdubbin86
    May 25, 2002
    55
    Alberta, Canada
    Ok. Thanks. That widens my search area. I'm guessing the suburban's should fit too then?
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Do be carefull on some trucks because the springs sit a little lower. I was given a set of k10 springs and they sat about 2 inches lower than the stock springs from the blazer. Food for thought.
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Those springs sitting 2" lower was probably from sag. Pickups tend to get overloaded a little easier than the blazers /forums/images/icons/ooo.gif
