Truck Tailgate on a K5
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by staceydude, Jul 25, 2004.
  1. staceydude
    staceydude Registered Member
    Jun 1, 2004
    62
    Keller, Texas
    Is it true a Truck tailgate form a regualr truck will fit a K5?
    If so how well does it fit and what all is required?
    I did the search function and nothing came up.
    Regards,
    Stace
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    wow thats something i havent heard of here yet, id like to see as well /forums/images/graemlins/thumb.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Yes, a truck tailgate will bolt onto a blazer. If you look at the bedsides you will see a set of holes, those are for the truck tailgate hinge. /forums/images/graemlins/thumb.gif
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i have a truck tailgate on my blazer. its a bolt on dea. lower portion of your blazer's bedsides has the welded in nuts for the reciver for the TG and the upper mid area has the hing/latch mount bolt holes.
    you have to remove ALL the hardware for the blazer TG to include the helper springs. those have a braket bolted to the frame and are kinda pain. i ended up cutting the springs because you would have to remove the bumper. then a couple days later i removed the bumper... oh well.
    its all bolt on and is weight saving, let alone soft top guys like it a bit beter from what i understand.
    grant.
  5. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    It's definately an easy bolt on mod, as long as you don't live in NewEngland and the lower part of the mounting area doesn't even exist anymore /forums/images/graemlins/angryfire.gif Then it's not so bolt on.
    Nate /forums/images/graemlins/k5.gif
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Very simple mod, and a good way to loose 130#
  7. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Yup---
    Just bolt the required tailgate hardware on and slap that baby on there. About a 30 min project!!!
  8. staceydude
    Jun 1, 2004
    62
    Keller, Texas
    Awesome,
    Thanks for the pics guys!!!
    I appreciate it. This makes my project ideas more of a reality.
    Regards,
    Stacey
  9. trailblazer86
    trailblazer86 1/2 ton status
    May 16, 2004
    112
    North Shore of Lake Ontario
    Nice bumper, and Rag top. Your picture has helped me make my mind. Mine will have a rag top also. What make is yours.
    Not much sense asking how It works in the cold. My parents lived in Amarillo about 50 years ago.
    Could you send me a few shots of your Jimmy? I would like to see the roll bar.
    My Blazer will be starting a frame off in September.
  10. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    /forums/images/graemlins/thinking.gif hmmmmmmm...i never thought about doing that, i hate having to use a key to get my tailgate open. only problem is wat to do about a window. im guessing you either need a soft top or go topless all the time witch i cant do. derf00 how much was your soft top and how easily was it to install?
  11. staceydude
    Jun 1, 2004
    62
    Keller, Texas
    There is a softtop review article written by Grim Reaper in the reviews sections. Looks lke a nice deal.
    I would also like to hear from Derf to see if his is the same brand and what the reports are onit.
    I kind of thought about getting a fastback style top made someone.
    Regards,
    Stacey
  12. hi pinion
    Sep 25, 2003
    5,354
    hey derf..... do you have any side shots for us to see? /forums/images/graemlins/thumb.gif
  13. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    [​IMG] [​IMG]
    These shots were taken the day the top was put on. It is a nice addition, and beats wrestling with the hard top. It does not flap on the highway and does not leak.
  14. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I have seen people use a p/u tailgate, and then mount a rear lift window off of a p/u canopy to their hardtop to use for a rear window. There was a guy on here that did a very nice job of it probably a year ago. I just go topless all the time, so I don't worry about it too much.
  15. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    Saw a blazer with a wooden/alum door from a camper shell attached in the back in place of the window.
    Was a work truck on a ranch, so they used it often.
  16. hi pinion
    Sep 25, 2003
    5,354
    that looks sweet /forums/images/graemlins/thumb.gif frees up some serious weight too /forums/images/graemlins/thumb.gif
