Truck Tailgate
Discussion in 'The Garage' started by uberbeans, Aug 25, 2006.
  1. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    What tail gate is used when changeing out the heavy Blazer one. I am going to but a Can-back soft top and thought that since I won't be using the back window any more that I could further save some weight by swaping it out. Anyone know which one and the weight difference?
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i havent done it but i think that its any 73-91 tailgate 87-91 being crew cabs, you will also need all the hardware from the tailgate and preferably the same color.
  3. uberbeans
    May 14, 2004
    564
    Is the tail gate a simple one for one swap? It fits EXACTLY?
  4. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I've been poking around looking to do this as well. As far as I can see from the LMC catalogue, and the responses here on CK5 the gate is a direct bolt on. The hinge and pivot styles changed at one point so be sure to grab a gate WITH its respective hardware.
  5. uberbeans
    May 14, 2004
    564
    Cool. I wonder how much lighter it is? I know the Blazer tailgate is really heavy. I think that I could save over 350 lbs. by switching to a softtop/truck gate.
  6. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You might save 75lbs with the swap, the blazer tailgate isnt THAT heavy.
  7. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    I took my trucks tail gate off, it weighed maybe 35-40lbs. I took it off to save some gas. not only in weight, but for the wind resistance factor. it is really easy to remove, like brackets and everything. If you are going to take it of another truck in a junk yard, make sure to bring some penetrating fluid. and also the bottom bolts in my truck almost took some sheet metal with them, so you may need new bolts, or what ever. but yeah very simple removal. ten bolts in all.
  8. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I replaced both the '73 and '75 ones with pickup tailgates. Just bolts right on!
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I put a tailgat off a 75 pick up on my 90 K5. It was a bolt on ordeal.
  10. uberbeans
    May 14, 2004
    564
    You guys are a perfect example of why I love CK5! Thanks for the info!:waytogo:
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    One tip...............run the correct size tap through the factory holes to remove corrosion and paint. :wink1:
  12. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    LMC sells a tailgate made for a K5 that didn't have the window I think.
  13. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    Hey dontoe got any more pics of that sweet ass rear bumper?
    Out of all the spare tire carriers I see I like yours the best.
  14. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I think LMC does sell a windowless blazer version, but for anyone in the Northern areas the Blazer hinge area is probably rotted. The pickup hinges on the side panels which is a great way to skirt the problem.
    Heed Dontoe's advice, I didn't and ended breaking the internal welded nut on one of the pivot mounting bolts.
  15. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Sure, I'm a proud pic whore.................
  16. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    My 73, the hardtop was an option and the part number for the soft top version was the same part number for the pickup tailgate for the same year. So even gm was using pickup tailgates long before us.
  17. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    alright, i have a 90 k5, and tomorrow i`m going to the swap meet and will be on the lookout for a gate, what year should i look for, and what should i make sure it has?
  18. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    '73-'87 P/U tailgate.
    But the parts to mount it may not come with it. Junkyard is a good place, since most/all tailgates are bought to replace another tailgate.
    Ain't able to photo mine now, maybe someone will post the parts pic!
  19. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    please, i will be going to the meet, and its the last one of the season, so i`m hoping to find one there, what is a reasonable price?
  20. uberbeans
    May 14, 2004
    564
    The LMC truck tailgate is like $600.00!!!!!!!!!!!!!
