Truck tool boxes
Discussion in 'The Garage' started by chevyfumes, Mar 6, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    where is agood place to find one I'm lookin' for a chest type so it can ride in my blazer, I want diamond plate and just big enough to fit in between the wheel wells and just high enough to be level with the bed rails. Ive found some on the net for about 200 but cant find any local I'm in Washington state...
  2. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    That's what I was looking for when I bought my plastic one at Wall-Mart. It's just a smidge higher than the rails but it was $35.00. The brand is Contico or something like that. It's not the most secure. It has two plastic tabs for padlocks on each side, but my 35" spare is strapped on top of it to deter theft. I couldn't see paying $200.00 plus bucks for the diamond plate one since I didn't wan't it bolted down. Having the diamond plate on bouncing in my rig would have beat it up. If you gotta have the diamond plate kind try an RV shop that sells accessories. I've seen them on travel trailers.
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Look for farm/ranch supply places in the phone book - or check out Home Depot, they sell small Knaack type jobsite chests for around $150.
  4. Grim-Reaper
    7,385
    Atlanta
    http://www.deltastorage.com/delta_new_truck_products.html
    I run a simular box to that. I had mine custom made by a company in Levern TN named Pro-Tech. That's what is known as a Underbed box. Mine measures 48wide x 18 tall x 20 deep. If you use this style you have to mount it about 1 inch off the floor to alow room for the hinge. I love mine. I run topless most of the year. Knowing that they would have to bust 2 locks to get my tools and gear is good. Never had a drop of water get in it. Even keeps dust out. Yeah it isn't cheap but a box full of tools can easily run over $1k to replace if it get's stolen. Then there is the HiLift I store in there when not on the trail, 2 tow straps, spare parts, hand winch etc. It would take an easy $1500-2k. The $240 I paid for mine was well worth it to protect my junk.
    I went with the side opening for a few reason. I had a Contico box before. Trying to get stuff out was a pain in the butt with the top on. This will let me strap coolers or gear on top and still have full access to the stuff in the box.
    Locking a plastic box....why bother. A swift kick on a Contico box will bust the plastic tabs off and your in.
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    go to an army surplus store and check outthe boxes they have there. may need to paint it but you'll end up spending like 30 or so for a good box.
    ARQ>
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Local Mil Surplus had some sort of big steel "ordinance" and "fuse" boxes (at least that is what was marked on them IIRC) for $50. I started to get one. They were about 3.5' long, around 1.5' wide and maybe 1.5' tall. They had like 6 heavy (locking) latches around the edges, a rubber seal that was water tight, and the lid could be completely removed. Pretty stout but I would need at 2 and didn't feel like paying $100.
  7. Greenblazer-AZ
    Jan 4, 2002
    770
    Chandler, AZ
    I don't lock my Contico the only theft deterance is the spare tire, and the fact that I park in the back yard. I guess it all depends on what you security needs and what you can afford. Those are some pretty sweet looking boxes though.
    Here's a pic, you can't see the box but the spare is on top of it: http://www.rockmodified.com/trails/fullsizerev/640/640_upperwood80.jpg
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    I had the same prob today sat on the web all day only to find what I wanted several times with no price tag finally i called this place close to me and asked if they had a chest type box (you know one that dosent require resting on the bed rails) in certain demensions, the guy says yup and asks what its fer, so I say my Blazer and he procedes to tell me (get this) You can't put those inna SUV they only go in TRUKS...Hmmm wish I's smart nuff ta have hissa job.../forums/images/icons/mad.gif
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Proof fumes leaves the lounge :thumb:
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    What was he thinkin'? :p:
  12. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    Fumes , I'm always finding good used Metal or plastic truck boxes on craigslist . You want one that fit's a little import truck . I had a metal one for the back of my burb and it fit just inside the bed with a few inches on each side and it rested on the wheel wells . I just bolted it through the wheel wells . I had to get rid of it when I put the blazer fuel tank in the bed . I've seen the for as little as $25 . If you are keeping your rear seat you can just mount it between your seat and tail gate as I think the one I had was about 55"x20"x17" . good luck :D
