Truck weight
Discussion in 'The Garage' started by Frickenwirthles, May 30, 2005.
  1. Frickenwirthles
    Frickenwirthles Registered Member
    Feb 21, 2005
    28
    North Idaho
    I just took out my 88 suburban out to the gravel pit to weigh it on the scale. 5800 with me, my girlfriend, a 70lb subwoofer box, and other misc. junk. Any body else done this before? I want to compare how much my beast weighs compared to k5's and shortbox, longbox, etc.
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    GOOD LAWRD!!!..i need to put my k5 on a diet! i make a dump run once a month, and have to weigh in and weigh out.. and the last time i went there, my weight empty(going out) was 6,328lbs...!! thats with me, a fullsize 35 inch spare, a tool box, a 3 1/2 ton floor jack, 4 tow straps, jumper cables, tire iron, spare parts, and a set of snow chains...
  3. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    My '89 Burb was right in the same area, with 14bff and 33's on steel rims, tools, and 12" sub.
  4. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Sheoldeblaze, do they weigh you on the same scale in and out? If so they might not worry about accuracy they just measure the difference. The best place to go is a truck scale, they are always accurate, just hit one on the side of the highway during quite hours.
  5. BIG*RED
    Mar 14, 2003
    1,094
    no its a differnt scale in and out..two lanes.. i usually hit between 6500 and 6600 going in and between 6250 and 6300 going out..
  6. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    4865 lbs in my K20 (long box,reg cab) with me sittin in it
  7. Frickenwirthles
    Feb 21, 2005
    28
    North Idaho
    Well, I guess I didn't expect a :k5: to outwiegh my :burb: Doesn't make me feel so bad about weighing close to three tons!
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I weighed my blazer at a truck scales a while back and it weighed 5880 with a full tank of gas, no spare, D60, 14ff, and that was without me in it.
  9. Frickenwirthles
    Feb 21, 2005
    28
    North Idaho
    Oh yea, I guess I did only have about half a tank when I weighed in at 5800.
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Last i scaled my Jimmy it was 1500 kg over the front wheels, 1200Kg over the rear. (3300lbs front, 2640lbs rear) 5940 lbs total.
    6.2 (dual batts), 465/205, D60, 14 FF, 39.5" TSL's, full cage and tube bumpers, hardtop on, full tank of fuel and me in it. I can drop 300-400lbs for trail though...
    rene
  11. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Stock '98 dodge/cummins with ranch hand bumpers---7200lbs
  12. Frickenwirthles
    Feb 21, 2005
    28
    North Idaho
    Well, I guess 7200 isn't too bad when you look at a Ford excursion, my buddy weighed his in at just shy of 9000!
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    26k lbs.....
    [​IMG] :D :D
    ok, the blazer RIGHT now... weights in at about 5.5k, but it will go up big time. soon...
    grant
  14. ronnny
    ronnny 1/2 ton status
    Nov 22, 2004
    838
    Newnan GA
    73 swb stepside in signature with toolbox and floorjack and me after dropping load of scrap metal no spares of anykind just under 4300 with 35 all terrians and cheap steal wheels. lots of rust to help in wieght loss.
