Truck Wont Move
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by big_bad_blazer, Mar 5, 2003.
  1. big_bad_blazer
    big_bad_blazer Registered Member
    Sep 19, 2002
    22
    yankton, SD
    ok hear we go. i had a 350 that locked up on me so i proceted to buy a 406 the 406 was conected to a 700 r4 trans. mine on the outher hand was a th350 i put th moter in and when i got the moter proforming the way i wanted i put it in drive and the truck would not move. my tork converted was smaller then a 700 r4s so i added shims inbetween the fly weel and the tork converter. it moved before /forums/images/graemlins/confused.gif so i was just wondering if any of you could point me in the right direction . thanks for any help
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    First, check the obvious...fluid level t-case in gear, and everything hooked up...
    Now you said the th350 torque converter is samller than the 700r4 TC? is it smaller in diameter or in depth?Why not swap in the 700? just a thought...make sure that the TC is seated FULLY on the tranny input...
    Chris
  3. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Oh, and fill out your profile before you get ousted....
    /forums/images/graemlins/thumb.gif
    Chris
  4. big_bad_blazer
    Sep 19, 2002
    22
    yankton, SD
    ok well the tranpher box was never un bolted for the tranny i left all that to gether. could any one help me out
  5. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    My guess is that the TC isn't seated right, but I don't know much about auto's
  6. big_bad_blazer
    Sep 19, 2002
    22
    yankton, SD
    ok if the tork converter was not all the way in how would i check that, and do you guys have enny outher explinations for this hapaning /forums/images/graemlins/1zhelp.gif
  7. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    ok first off let me ask this question what transmission and torque converter do you have in there? if it's the 700 with the 350TC you will burn up the tranny + it wont work. It won't seat all the way in. If you have a 700r in it you need a 700r TC, If you have a th350 in it then you need a th350 TC ok hope this helps.
