Truck Won't Start Help!
Discussion in 'The Garage' started by blopez, Aug 13, 2006.
  1. blopez
    blopez Registered Member
    Jul 25, 2005
    35
    Dana Point, CA
    I got her started about two hours ago, but now nothing. Some Facts:
    454 GM - 750 Double Pumper Holley - New Plugs
    I suspect problem with carb setup - Truck usualy starts at end of starter/key turn (after holding key at start(starter cranking over engine fine) and on the way back to run on key - the engine will putter a few times and start. intermittent before and now won't start at all.
    When she starts it'l stay running.
    CAP AND ROTOR?
    PLEASE HELP
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    what has changed since it last ran?
  3. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    In the other thread, someone mentioned the ignition switch. Look into that. You could bypass it with a jumper to see if that's it, or you could just try a new switch (they are quite cheap - I keep a spare in my console, along with a brake light switch, and a few other things).
  4. TheSunDanceKid
    TheSunDanceKid Registered Member
    Jul 22, 2006
    60
    arizona, gilbert
    to test to see if your ignition switch is bad just hot wire it go to the12volt.com get the wiring diagram to install an alarm and it will tell you the colors take the "constant 12v" and "ignition" touch them together all your dash shiotand radio should come on as if the key was in the "run" position keeping those 2wires together and just a quick touch to the "Starter" wire should make it crank if it does then its your ignition switch but of course dont use this info for theifing cars :)
    red=constant12v pink=ignition purlple=starter
    heres a shioty paint diagram and remember to use the 2fuses
    the color wires on this are for 1978-87 Chevrolet C/K Pickup
