Truck Won't Start :)
Discussion in 'The Garage' started by blopez, Aug 13, 2006.
  1. blopez
    blopez Registered Member
    Jul 25, 2005
    35
    Dana Point, CA
    I got her started once today and that was it, I replaced the plugs, there is fuel in the caberator and when it started it started as soon as I let off the starter. I has had problems starting in this way before, where it will start RIGHT AS I turn the key 1/2 way from start to run. I think it may be a problem with the Carberator I don't know much about carbs Any help?
    1972 GMC 454 Holley 750 Double Pumper,
    CAP and ROTER?
    HELP
  2. wetbackZO
    wetbackZO 1/2 ton status
    Jan 30, 2006
    113
    Las Cruces, NM
    sounds more like a bad ignition switch...check it out.
