truck wont start
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Nov 25, 2001.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 and this morning i went to start it and it wouldn't start, i have all power, radio and everything else works, I can hear the starter turning over its just that it wont start, what could this be?
  2. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Check the battery guage on the dash. If its below 8 then its the battery. You are mostlikely going to have to get a new alternator. I foud out about this on Thanksgiving at 11:30 Pm. It sucks luckely your at home (I would amagin)
    Good luck, KEN
    DANGIT it's not a bronco!
    <a target="_blank" href=http://community.webshots.com/user/kensk5>My Picts</a>
  3. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    Check your ignition module, coil, and wires. Might be one of them.
    I just got lost in thought, It was unfamiliar territory!
    88 K5... work in progress
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    you say you hear the starter motor running, is the starter engaging the flywheel and turning the engine over, if it's not it is the drive in the starter, get your starter rebuilt or get a new starter.if it is turning the engine over, check to be sure your getting gas to the carburetor and spark to the spark plugs, this will get you started as to why it isn't starting.
    '95 Chevy Silverado 1500
    5.7 V8-NV4500- 3.73 rears
  5. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    well you are going to have 1 of 2 problems; 1 - it isn't getting fuel (maybe water in the gas or something), or 2 - it isn't getting spark.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
  6. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    I recently had the same problem. I had just replaced my starter so I didnt think it was that but check it out first. I found the problem to be that my cap and rotor were burnt pretty bad and pieces of the metal plate that sit on the rotor had been torn off and missing. After I replaced those thing It satill didnt start so I replaced all of the spak plugs the old ones were fouled.
    1985 GMC JIMMY
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    yea I broke the coil mounts once (don't ask me how I still have no clue), and it burned out the coil. sounds kinda simliar to your situation.
  8. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Does it have gas in it? [​IMG]
    Like wookie said. It either is not getting fuel or it aint getting spark. Those are the only 2 things that could cause you a problemo as far as starting goes, except that maybe thay aint getting spark and fuel at the same time! [​IMG]
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  9. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Well like every one else is saying....fuel or fire? I'd pull one of the spark plugs and put the wire back on it. Take the spark plug and lay the end against something with a good ground, like the manifold. DO NOT TOUCH IT after getting in position. Have a buddy go crank the motor over, now watch the plug. You should have a big fat blue flame jump the gap if you're getting fire.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
