Trucking POS
Discussion in 'The Garage' started by k5freak44, Jan 27, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    Hey guys i started to put my body lift on today.
    It was going smoothe unitl i hadto actually lift the body up.
    I was using a 4point hydrolic lift and lifted both sides at the same time.
    Here comes the problem, somehow my body has shifted 1inch back and i cant figure out how to slide it back so i can bolt it to the chassis. I want to toss the body lift for now and just get the body back on the frame, then later do the traditional way, by doing one side at a time. All i need to know is the best way to slide the body so i can get it back ontop of the mounts and so i can get my bolts thru agian.
    Thanks Againnnnn
    John
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i do it all the time this way. you must block the tires first. the frame rolled on you. pick it up and rool frame back to the correct spot.
  3. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    You mean like a shop lift? If so, why not move the chassis back (instead of the body)?
    Are the tailgate springs still attached to the frame?
  4. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i tried that, but its just not working. can i put it in neutral with the auto shifter or can i just use the 4wd shifter.
    when i tried the tires would spin on the ground as i pushed on them but the chassis wouldent move.
  5. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    Thats The Problem!! Tailgate Springs!!! Thank You. My Tailgate Sounded Funny And I Had No Idea What It Was.
  6. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    When I took my body right off, it shifted back 2-3 feet:crazy:
