Truckliner question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Kell, Jun 8, 2003.
  1. K5Kell
    K5Kell Guest
    Just pulled all the carpet out of the blazer only to find the bed to be corpsed up on the inside /forums/images/graemlins/smirk.gif. It looks like wrinkled aluminum foil. Im going to put bedliner in but dont want to have to see the damage all the time and its way to much to fix or even putty. Any ideas or advice would save me alot of time. I was thinking of putting something like a plywood panel in there but wasn't sure how that long that would last wheeling /forums/images/graemlins/confused.gif.
    -Kell-
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    por 15! thats what im always hearing on here, do that then bedliner it...
  3. K5Kell
    K5Kell Guest
    Rust is not the problem. its just that the metal looks like Oprahs thighs, theres no way to fix it /forums/images/graemlins/grin.gif. I need to find a way to cover it without having something that cant handle flexing out the blazer. thanks anyway.
    -Kell-
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I say take a good wire wheel on a grinder or just a grinder to the whole thing. That would take care of the problem. Might be more work than you want though
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Take a disc grinder or a coarse wire wheel to it and spot and fill primer it. If that's too much like work take the disc grinder to it and Herculiner the whole floor.
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    You could always Rhino line it if you have the money.
  7. K5Kell
    K5Kell Guest
    Thanks for the suggestions, but its so wrinkled that Im gonna need something to cover it, especially since its on both sides and looks terrible /forums/images/graemlins/frown.gif. theres already alot of other dents I have to take out so something rather simple and quick would be the best. It's amazing how much stuff the carpets can cover up /forums/images/graemlins/tongue.gif.
    -Kell-
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Dosent POR15 make you rig weight 2490148LBS?
  9. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    How about por 15 or truck bed liner then cover it with a rubber bed mat? That's what I've got in mine right now. Keeps the rattling down! Only other thing I could think of would be a few dozen cans of bondo. /forums/images/graemlins/grin.gif
