trucks acting funny.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FatBoyBlazer, Mar 31, 2002.
  1. FatBoyBlazer
    FatBoyBlazer 1/2 ton status
    Feb 22, 2001
    1,508
    Worcester, MA
    it runs fine went its ben running but on the start up it some times stalls out on me for some reason other than that it runs fine........could it just be a loose distirutor cap???.....and if i can figure it out whats wrong with it the the Mah Dukes is going to make my get rid of it...so i need some help...also i tend to drive fast to xtreamly larger pudles(so water might be getting in places its no suposed to be.....thanks....ryan
  2. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    If it is on the startup it could be your choke. It may not be engaging which will make it run bad on startup. My blazer had this problem and I could barely keep it running, especially in the cold.
  3. FatBoyBlazer
    Feb 22, 2001
    1,508
    Worcester, MA
    its tbi not carb
  4. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    Your cold start injector is bad. It's the sensor right next to the thermostat housing. Mine would start hard, run like a pig until warmed up but after that it ran like a top. So, I would try the cold start injector.
    Ben 87 Jimmy
  5. MudbogAD
    Jun 29, 2001
    672
    Well I didn't know that because it wasn't stated. It was just an assumption.
