Truck's almost undriveable?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rocky91, Nov 8, 2002.
  1. Rocky91
    Rocky91 Registered Member
    Feb 14, 2001
    44
    Rochester, NY
    Truck\'s almost undriveable?
    The short version is my truck idles irratic when warm and it stalls out while driving. It takes a few tries to get restarted but I have to hold the gas pedal to the floor. Also today after restarting it was idling at 1800 rpm's. I'm out of ideas, I've replaced almost everything except ignition, computer and MAP sensor. Anyone have any thoughts?
    Here's a list of everything I've replaced in the last 3 months:
    - Rebuilt top half of engine
    - TPS Sensor
    - IAC sensor
    - Oxygen sensor
    - Spark plugs, wires, rotor & cap
    - Temperature sensor
    - Fan switch/sensor
    - Fuel & intake filters
    - checked vacuum lines
    - checked timing
    - checked fuel pressure regulator
    HELP!
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Re: Truck\'s almost undriveable?
    How did you check for vacuum leaks?
  3. Rocky91
    Feb 14, 2001
    44
    Rochester, NY
    I checked visually all the lines and with propane torch along the areas in question. I also I forgot to mention its a '91 TBI 350. Thanks.
  4. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    Have you checked the dist. pull it out and move the shaft l to r if any slop it is junk also if there is oil on the stator and module it is junk ,just a thought
  5. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    we had a similar problem on a 2.8 corsica.
    it was the computer. a lot of people unjustly blame the comp... we really didnt think it was the problem. it was.
    reman was 65 dollars
  6. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    i had the same issue with my 1987 and i found my little Gremlin was the EGR valve was sticking bad, so i took a little sharp object and punctured it, "it worked alot better and long enough to get a replacement" for it.
    kinda weird but then again it happened to me hehe
    hope this helps
    Ck1500 /forums/images/graemlins/ears.gif
