TRUCK'S PULLIN ! SCAREY S#@$%T UPDATE,UPDATE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bklynlifted, Oct 28, 2002.
  1. bklynlifted
    bklynlifted 1/2 ton status
    Feb 4, 2002
    261
    brooklyn ny home of the brave
    TRUCK\'S PULLIN ! SCAREY S#@$%T UPDATE,UPDATE
    ok so im heading to the mountians to go deer huntin, yes brooklyn guys hunt. i noticed when i apply the brake at highway speeds she pulls to the right so bad that i have to compensate by turning the wheel to the leftand then when i let off the brake the truck will now shoot to the left really scary at 70mph.ps if i let go of the wheel the truck goes down the road straight as an arrow. so where do i start. ps i keep te hubs locked if that helps??????? thanks /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif--------- OK everything is fixed i needed 2 calipers the right side was binding so as i applied the brake it would grab the rotor first sending me in to the next lane, also chaged t pads, and both brake lines bendix)$$44.00 each /forums/images/graemlins/ignore.gifOUCH and changed the gear oil in the rear i got about 500 miles on the rear and so far it's working out OK . so i'm off to the catskills tomorrow afternoon for 5 days to go shoot bambi with my bow /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gifthanks to all who gave advice once again CK5 people give good advice as to what to look for. thank /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/rolleyes.gifs jack <font color="red"> </font color>
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Re: TRUCK PULLS ! SCARY S#@$%T
    Tire pressure?
  3. bklynlifted
    Feb 4, 2002
    261
    32lbs all around /forums/images/graemlins/thumb.gif
  4. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    Sounds like the caliper is hanging up. My truck was doing that, take the caliper off and look for rough surfaces on the caliper and pads. Everthing has to be able to slide easily. Just use a flat file and smooth is out.
  5. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Definately check the brakes. Same thing has happened to me with two seperate GM 4x4s.
  6. bklynlifted
    Feb 4, 2002
    261
    ttt
  7. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    the caliper piston is hanging up replace or rebuild the calipers.
  8. bklynlifted
    Feb 4, 2002
    261
    thanks guys i guess i will swap in some new calipers i went to autozone site and they listed LOADED calipers what duz that mean????
  9. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    with brake pads attached from what I heard
  10. bklynlifted
    Feb 4, 2002
    261
    cool thanks /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  11. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Re: TRUCK\'S PULLIN ! SCAREY S#@$%T
    why do you keep the hubs locked?
  12. bklynlifted
    Feb 4, 2002
    261
    i dont think it can hurt anything and it saves me the hassle of getting out and locking them when i shift into /forums/images/graemlins/thumb.gif 4wd
  13. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    either a sticky caliper or a collapsed brake line is my bet... also put light lube on the guide pins while its apart.
  14. 76k5Blazer
    76k5Blazer 1/2 ton status
    Sep 25, 2002
    176
    tracy ca
    Leaving the hubs locked puts extra wear on the carrier bearings, ring and pinion, front drive shaft , Tcase front yoke bearing the t case gears because your spinning the front shaft cause the hubs are locked .all of these are not normally spinning when the hubs are unlocked.
    Loaded calipers are the calipers with pads /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  15. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If all this doesn't cure it, check the rear, if there is a brake fluid leak you would have that.
  16. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I agree with BowtieBlazer on the collapsed brake lines. If you still have the stock rubber lines, they've been prone to swelling. Mine did the same thing a few years ago. I replaced the lines, bled them well, and it hasn't bothered me since.
  17. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Mine started to do this worse and worse and worse.
    It turns out the U bolts on the spring packs worked their way loose.
    Check your spring packs and all steering components.
    Good luck.
  18. bklynlifted
    Feb 4, 2002
    261
    so i guess i gotta check the calipers and brake lines i heard that if i'm pullin to the right then it must be my left front caliper thats got the problem?????or left front brake line?? /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  19. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    so wouldn't it be like the old hubs??? mine didn't come with manual- so I"d asume that those are causing excessive wear....I keep mine locked in 24/7/365.....
    Brandy
  20. bklynlifted
    Feb 4, 2002
    261
    i dont by the excessive wear thing cause both wheels are spinning no matter what position the hubs are in. i can see 4wd and you have torq applied to both wheels like going around corners ao dry pavement?? just my opinion i really dont have much time off road and i'm still learning /forums/images/graemlins/thumb.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
