Trucks with D60...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bigblue, Jun 21, 2001.
  1. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Exactly what trucks came with the D60 that we need for our application? Will Dodge and Ford D60's work? I am driving myself crazy because I want one SOOOOO bad! But I will not pay BIG BUCKS for one. thanks.
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    77 to 87' (91' Crewcab) 1 ton chevy P/U has em.
    84 to 86 or 87' (forgot) CUCV's has em.
    Ford D60 has a Driver side pumpkin.
    Dodge perches are off by an inch. Maybe can be fabbed to work, maybe not. I would stick with GM (the two listed above) (and yes, big bucks); if you're lucky, you might be able to find em cheap(er). Good luck.
    Boss
    89' 1 TON of FUN K5
  3. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    I have the HD 76-89 Dodge W350 front Dana 60. The light duty Dodges have a weaker 3500lb axle. The spring perches were off by 1/4" on each side. I welded a 1/4" plate to the sides of the spring perches and partially filled the spring pin hole. Then I carefully opened up the spring pin hole a 1/4" over to line up with my K5's springs. But the big difference is the manual hubs are external knobs that are only made by Mile Marker. You can change the spindle, rotor/hub, and manual hub to GM and have the standard Warn hubs. I feel for you, I went through the same thing and ended up paying $1000 for my front and rear Dana 60's.
    CB
    1973 K5, 400TPI,TH350, 203/205, Dana60/Detroit/5.38 front and rear, 38" TSL's on steel wheels
    <A target="_blank" HREF=http://www.azk5.coloradok5.com>http://www.azk5.coloradok5.com</A>
