True tire measurements. Reply here. *I'm looking for 36/12.5 SX.*
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Twiz, Mar 10, 2002.
  1. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    True tire measurements. Reply here. *I\'m looking for 36/12.5 SX.*
    I did a search, with no luck. So, I thought it might be usefull to pool our collective tape measures togather and post some "ture" measurements of our tires.
    Copy/Past and fill in the blanks.
    Tire type/style and size -
    Overall tire height -
    Tread width -
    Section width -
    Rim Dia and Width -
    % of tread wear -
    Tire type/style and size: Like, BFG Mud Tarrain T/A 35/12.5 X 15.
    Overall height: Measure the loaded tire height, witth street air pressure (30 + PSI)
    Tread width: Measure the width of the contact patch, with Super Swampers, ball-park the lugs.
    Section Width: Overall width, maximum width of the tire's sidewalls
    Rim dia and Width: This can have a impact over the overall measurements.
    % of tread wear: 100% would be new, O% would be into the cords.
    *I really need the measurements for a 36 X 12.5 15 SuperSwamper SX.*
    If someone has this tire, and could get the measurements, I would be very greatfull!
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Re: True tire measurements. Reply here. *I\'m looking for 36/12.5 SX.* *DELETED*
    Post deleted by Twiztid
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    OK, I run
    35x12.5x16 Super Swamper SSR's
    Mounted on 16x10 589's
    Actual height 34.25"
    Tread width - 12" apx
    Section width - no idea, need a huge set of calipers........
    Have about 5K on them, wearing great.
    FYI - Shannon (mudhog) has
    38x13x16 TSL's (non-radial)
    Overall tire height - are you ready? 36"
    6.5" wheel width (think that's what he said)
    No other measurements, maybe he can help ya.
    Brand new tires.
    Kinda ridiculous the actual height measurements vs. advertised............Cheech from Up in Smoke - "Hey, man, that's false advertising!"
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Tire type/style and size - WildCat EXT: 33x12.5"
    Overall tire height - 31"
    Tread width - 10"
    Section width - 12"
    Rim Dia and Width - 15x10"
    % of tread wear - 60% left
    With no vehicle weight the tires are aroud 32" tall
  5. shaggyk5
    shaggyk5 1/2 ton status
    1,610
    SE pennsylvania
    Tire type/style and size - Swamper TSL 35/15/15
    Overall tire height - 35"
    Tread width - 13.5"
    Section width - 15"
    Rim Dia and Width - 15x10 black steelies.
    % of tread wear - 25%
    These taken with tire/rim OFF the truck @ 20psi
  6. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
  7. BurbinOR
    5,829
    Oregon
    By the way, took tire off last night to install wheel spacers, measured at 34.50 unloaded.
  8. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    Twiztid, I have 36x12.50 x 16.5 Super Swamper TSLs . I used the spare for measurements which has not been used so it has 100% tread. I pushed the tire up against a wall on its side and used a level and tape measure to get these measurements:
    Height = 36.0 inches
    Section width = 12.75 inches
    Tread width= about 11 inches (hard to measure due to lugs).
    Rim Size= 16.5x9.75 inches
    Hope it helps!
    JT
  9. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    The "Deleted By Twiztid" replys are nothing more than "Thank yous" and such. (evidently, you can-not erase a reply after a certain amount of time)
    Replys deleted in an effort to keep the post un-cluttered.
    Thanks, again to those that have contributed.
