truetrac carrier bearings help
Discussion in 'The Garage' started by GM4wheeling, May 28, 2006.
  1. GM4wheeling
    GM4wheeling 1/2 ton status
    Apr 10, 2006
    337
    Ft. Bragg NC
    I've posted this question in a different thread, but i sorta went a little off topic and no one responded. But I really need some help with this, can't find the info anywhere. I have a 10 bolt rearend and I got a truetrac for it. Now the stock carrier bearings don't even come close to fitting. I have found out that some kinda locker from auburn and the truetrac are the only carriers that use these bearings in the 10 bolt that I'm looking for. The perfomance offroad shop here says they know NAPA has them, cause they've gotten them from them before, but usually the unit comes with papers with part numbers for these bearings but mine didn't. So I have no idea what bearings I need! :confused: If anyone knows or could point me in the right direction I'm all ears:ears:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Call randys ring and pinion. they will know
  3. driney
    driney 1/2 ton status Premium Member
    Jul 6, 2001
    699
    7
    west central illinois
  4. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    we installed a posi for a guy onetime. it said if you use this in a late 80s or newer 10 bolt use the stock bearings. if in the older axle use the newer style in the older axle.
  5. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    quite possible, the newer ones with the 30 spline axles use larger bearings
  6. GM4wheeling
    Apr 10, 2006
    337
    Ft. Bragg NC
    Thanks guys, i had started my own tread to find the bearings and i got the answer.
