truetrac vs. lockright
Discussion in 'The Garage' started by tree_entz, Jul 23, 2004.
  1. tree_entz
    tree_entz 1/2 ton status
    May 4, 2004
    141
    N. Vermont
    ok, refined my question a bit.
    they're aobut the same price. how about the install???
    sled_dog said the lockright is cake.
    is the truetrac better though??? thoughts please???
    (for front dif 10bolt)
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    True Trac is a full case unit , helical geared no clutches very quiet , only biases torque around 2.5 to 3.5 range . Lockright ( or variants like mine ) will lock up 100 percent , and still work as a diff for corners . Will be noisy in a rear application , but fronts are quieter /forums/images/graemlins/k5.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    There is no comparison between the two. One a limited slip unit (basically a fancy open diff when you're off road) while the other is a locker.
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I just got done saying that ( 2.5 to 3.5 bias , versus 100 percent ) /forums/images/graemlins/deal.gif
  5. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Just curious how you figured this without knowing engine power, tiresize, ect.?
    Do you mean that with an axle with 100 lb-ft to it, one tire off the ground, the other tire on the ground it will still have 2.5- 3.5 lb-ft to the one on the ground.
    Maybe if there is that much resistance to the tire in the air but with no resistance it spinning 100% with no basis to the tire on the ground.
    Cones or friction material on plates, it's still friction which can be overcome!
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Simple , I looked on their website Tractech Detroit True Trac
    So basically if you have 100 ft lbs going to the front diff , with open when one tire goes airborne all 100 ft lbs spin in the air , with the true trac more power will be distributed to the tire that is stuck in a ratio of 2.5 to 3.5 of that 100 ft lbs ( so like 70/30 split ? ), but never ALL of that power . Perhaps I should of been more clear . Oh and the True trac has no clutches , just helical gears /forums/images/graemlins/k5.gif
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    The TruTrac has neither since it's a helical gear-based torque biasing design. The bias rate is determined by the design of the differential itself and is not dependent on any other factors. The higher the bias rate in this type of the diff, the "tighter" it is.
    If you have one tire off the ground on an axle than it is theoretically receiving zero torque......if there's not torque to one side than it can't "bias" any torque to the other size (zero times zero = zero), and is thus why this diff doesn't do much good with one tire is lifted off the ground. Though riding the brakes a little in this situation really helps (I used to run a TruTrac).
