Truggy guys, lets see rad. mounts
Discussion in 'The Garage' started by 85mudblazin, Feb 1, 2006.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am trying to find ideas on how to mount the top part of the radiator (already have the bottom figured out.
    My radiator will be laid back a little. I want to have a clamping type upper mount so that when you tighten it down it clamps onto the radiator.
    So lets see em':wink1:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Me too , I am subsribing to this thread . I am leaning that way , as far as raking it back .
    Side note what fans ya running ?
  3. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    not sure if this is what you guys are looking for? but i used a 1st gen upper and lower rubber insulator set the upper brackets i used a simple angle iron bracket with a vertical slot with 2 bolts to tighten the bracket in place.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I have a Taurus fan. Hang on ill go snap a pic.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    OK So the camera button wouldnt shut off:D
    Heres hows it will sit.
  6. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just wondering, why tilit the radiatotrs back? for protection?
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Taurus fan. Its a pretty simple mount.
    Heres clearance between fan and engine.
    Heres how the top sits. Shouldnt be to hard to figure some thing out. It will be about 1/2" lower to clear some tubes going on the "hood" area.
    Then my lower mount is just a piece of 2"x2"x1/4" with the top cut off, I then lined it with that rubber bed mat stuff.
    Ill just fab up a hinge setup so it will make it easier to get the rad. in and out.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Oops looks like there a double.
    Heres the missing clearance pic.
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    To get the front as low as possible for better vision.
  10. 79k20350
    Nov 22, 2004
    7,757
    Ct
    Doh! i completely forgot about that. i remember now that thats why cybersniper did his. (i just happen to remember his build real well, i was following it when i was first getting into offroading)
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You cant see it here but this is the best pic I have of the whole things.
    I used an aftermarket AL radiator. I used to peices of angle for a base (2"x2" and a stick of 1" by 1" so the bottom does not move anywhere. On the front side are two tabs welded and they are bolted to the supporting posts. I dont have anything up at the top but it isnt moving anywhere.
    Not sure how I would have done a stock radiator but some type of upper clamp with a lower bucket to keep it in place would have worked I guess. I kow in my last setup, I had problems witht he radiator comming loose and I had to build some lower retainers as the stock clamp and bushing system would fail on a hard hit.
  12. CK5
    May 19, 1999
    21,622
    701
    CO
    On the UAV
  13. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    here is mine just finished tonight
  14. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    That is focking great! I think that's the best setup I've seen on a buggy. Great job. :waytogo:
  15. MNorby
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    i ended up putting 1" heater hose down the chanel of the top and bottom of the radiator to isolate it too. Worked out great.
