tRusty is sitting on 57's now (early spy pic's up now...)
Discussion in 'The Garage' started by tRustyK5, Jul 17, 2002.
  1. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    tRusty is sitting on 57\'s now (early spy pic\'s up now...)
    I'm not quite done but she is back on her tires with the 57" long Ford F-150 springs under her./forums/images/icons/cool.gif/forums/images/icons/cool.gif
    I recently picked up a used set off a 90 F-150 and spent 3 days grinding, buffing and painting the indvidual leafs. I added new UHMV slip pads and new center bolts and coated each leaf with 3 good coats of flat black epoxy paint. I redrilled the center bolt hole 1.5" farther back to keep the axle centered in the wheelwell.
    I did a poor mans shackle flip by cutting the bottom out of the hanger and gusseting the top side of it. I extended my shackles 1.5", and I moved the hanger back 2.5".
    One thing that I found out was the Ford springs use a 7/16" center bolt so the head of the center bolt does not fit the 14 bolt diff perch. I had to open up the hole to 5/8" for them to drop in. Using the stock perch location I'll need to add a 3 degree shim to get my pinion angle where it was before...that's on tomorrow nights list of things to finish. The U-bolts haven't been torqued yet so it shouldn't take long.
    I have been taking detailed pic's of my progress at each step including a few with the tape measure out for comparison to the 52 stock spring. As it sits right now (no topper on it) I gained 1/2" of lift without adding or removing any leafs from the stock 57" leaf packs I bought. I used the 4 leaf + overload springs. I figure it should settle down to the same height with the top back on due to the much softer spring rate.
    I will also get some ramp pic's (our club has it's own RTI ramp). My previous numbers were 935 frontwards at 20 degrees and 1065 backwards at the same angle. I am hoping to pass those numbers by a fair margin.
    As a side note I did all this on my back patio and in the single carport we have a home. I normally beg my boss for the shop at work but I no longer have that job so I had to do it the hard way.
    Rene
    *edit* check mj's post below for spy pic's...no laughing at the chrome exhaust tips please!/forums/images/icons/crazy.gif
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Re: tRusty is sitting on 57\'s now
    SWEET!!!!
    I found a set here for the wagon./forums/images/icons/cool.gif
  3. ol_grayfeather
    ol_grayfeather Registered Member
    Jan 15, 2001
    68
    Around Spokane, Washington
    Sounds like you've been busy...dont forget the pictures!!!
    Dan
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    congrats brother cant wait to see the pics /forums/images/icons/grin.gif
  5. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Okay...so you beat me to the furd springs....but I got cha on the vertable thing /forums/images/icons/grin.gif /forums/images/icons/laugh.gif
    Me would like to see dem pics /forums/images/icons/grin.gif
  6. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    Aaaah, the ol' back patio trick. i've done 2 lift kits and a motor swap on my back patio. hey, its the flattest place for me to work /forums/images/icons/laugh.gif luckily the wife didn't care. /forums/images/icons/tongue.gif
    can't wait to see pics, Rene!
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Awesome, Rene! Pics ought to be cool.......... /forums/images/icons/tongue.gif
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    Cool Beans!!!!! When you did the flip, how much did it bring your pinion up?
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I thought you had gotten some 57" tires!
  10. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I took some measurements from the edge of the pinion yoke to the ground with my old 52" springs and the pinion came up 5/8" higher with the 57's. A 3 degree shim brought it back down a little over 1/2" so it's really close to where it was before.
    Rene
  11. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    LMAO!!! That would be much more impressive than 57" springs... /forums/images/icons/grin.gif
    Rene
  12. greatwhitenorth
    greatwhitenorth 1/2 ton status
    Mar 10, 2002
    102
    Surrey, BC
    Sounds like a nice setup Rene, lets see the pics!
    What 4x4 club do you belong to Rene?? Are they outta Surrey or elsewhere?
    Any chance I could tag along on a club run when I get back at the end of August.. If my rig will make the grade of course.
  13. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    The pic's are being developed, so they should be up in the next coupla days.
    I belong to a club calling itself "The Herd of Turtles" or H.O.T. for short. Lots of Jeeps (mostly XJ's) and little trucks, quite a few near stock...I joined because they wheel really often and seem to have a friendly attitude. Tag-a-longs are welcome...
    Shoot me an email when you get to the coast and we'll do some wheelin!!!/forums/images/icons/cool.gif
    Rene
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    LMAO!!! /forums/images/icons/laugh.gif I thought you got 57" tires, too!!! /forums/images/icons/laugh.gif
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you should borrow my digi camera for projects like that.
    waiting for pics is so 80s
  16. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Re: tRusty is sitting on 57\'s now (Springs, not tires)
    I don't have room at my house to borrow any more of your stuff/forums/images/icons/shocked.gif /forums/images/icons/grin.gif Besides I like the suspense of waiting to see if any turned out worth sharing.../forums/images/icons/smile.gif
    I got it all done now and i still can't get over the diference in the ride back there. Those springs just soak up the huge speedbumps in our complex like they were made of liquid /forums/images/icons/cool.gif /forums/images/icons/cool.gif
    I'll get it on our club ramp for a head to head comparison from the 52's to the 57's. The last time I ramped my truck the only thing different was the rear springs.
    Rene
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sounds like you need to move to a bigger place
    those heepers you ride with will never give your truck the respect it deserves even though you were already outramping all of them prior to the new stuff.
    your next run you should try a bump n pass style, you should borrow my tire chains for that
  18. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    No more snow wheelin for a while...
    Those 'heeper' friends of mine were over checkin the new springs tonight...I'm hoping they are there when I ramp it./forums/images/icons/smile.gif
    [/ QUOTE ]I did that at Walker Valley in the snow...I don't recomend it./forums/images/icons/laugh.gif "Damn trees..."
    Rene
  19. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    not the trees THE HEEPS
  20. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    congrats man!! /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
