try and figure this out
Discussion in 'The Garage' started by dick_landy, May 3, 2007.
  1. dick_landy
    dick_landy Registered Member
    Mar 17, 2007
    82
    winnipeg,manitoba,canada
    ok, dont give me too much of a hard time but i figured if any place would know more about these trucks it here.
    I bought a 90 suburban for my wife, the only thing is its 2wd :shocked:
    Now I just finished putting in a set of bell tech #3100 dropped spindles and now the passenger side is 1" higher than the drivers side.
    On to the confusing part.
    -I double checked to make sure the spindles were the same and that the spindle shafts were in the same location and they are.
    -I measured both sides from the floor of my garage to the bottom of the lower control arms and the measurements are the same.
    -I measured the distance between the lower control arms and the spring cup/bucket on the frame and they are the same.
    -The coils are sitting in thier place like they should,plus i never removed them. The jack stands never left the lower control arm the entire install.
    If it had to do anything with the suspension then one of those measurements would have to be conflicting.
    When I measure from the floor to the fender lips in line with the hubs its an inch out, same with the bumpers. Even the space between the tire and fender lip is different between the two. I don't think its the floor because it doesnt matter where the truck is, it looks uneven.:confused:
    I checked the rear leafs to make sure none of them were broken and they are fine. It does seem to me that the front passenger side seems stiffer when I bounce it up and down compared to the drivers side, but again, why are all the suspension measurements checking out ok?
    I am clued out, am I missing something? :1zhelp:
  2. balterbuilt
    balterbuilt 1/2 ton status
    May 10, 2004
    385
    Santa Rosa
    take the tires off and post up some pics. I would be suspect to the fac that one spring might be saging. I think the main problem is that the suburnban is unhappy that you are building a pavement pounder and not a prerunner out of it and now you are showing everyone on the off-road forum it's unhappiness :-P
  3. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Did you measure before you installed the spindles to see if the truck sat level?
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Look at where the spring sits inside the buckets. Make sure the ends of the springs are sitting where they are supposed to. The buckets have a 'place' (for lack of a better term) for the end of the spring to sit.
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Well how did these measurements compare before you started?
    It is not unusual for these old vehicles to sit crooked. The normal culprits are bad body mounts and sagging/broken springs. You didn't say if it was also crooked by 1" in the rear. Also, if it has ever been in a collision that can make anything crooked.
    It's also possible that during your spindle swap the sway bar got wound up and is stuck in place.
  6. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    didn't think about that but as blue85 mentioned it could be body mounts as well.
  7. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Im betting sagging body mounts. if the suspension is all the same then its the body thats not level. measure to the top of the frame and that will tell you where your problem lies.
  8. dick_landy
    Mar 17, 2007
    82
    :D it was too pretty to make into a pre runner! but if it makes all yall happy, my plan was when it starts to look its age in a few years i would transfer the body to my other burb seeing as how the rocks and mud have really taken its toll on it. at least then it will die happily!
    i never measured before hand :doah:but it never was noticable before,now it is.
    i checked out all the body mounts and they all look pretty darn good except for the passenger side near the rear wheel. the springs look like they are in thier "place" but i will check again. I will keep checkin stuff out. who knows maybe the springs and sway bar need to settle for some reason.
  9. balterbuilt
    May 10, 2004
    385
    Santa Rosa
    pictures speak a 1000 words....
  10. dick_landy
    Mar 17, 2007
    82
    just curious, what are you looking for in a picture? what do you want to see? do you want to see the suspension drooping or the weight on the control arm?
  11. enginenine
    enginenine Registered Member
    Apr 7, 2006
    85
    Loxley, AL
    Agree with mudstud. Sounds like the spring is twisted and not sitting in the control arm right.
  12. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    Have you driven it around the block yet? IFS suspensions have a noticable track change with travel. If you dropped it down off the jackstands one side at a time, it may be that one side isn't able to settle to its normal ride height due to the friction between the tire and ground. I hope that makes sense. Its worth a shot and its and easy "fix".
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I'll bet that it sagged before you started but you did not notice it because of the distance from the ground. The closer the body gets to the ground the easier it is to see such things that weren't apparent beforehand.
  14. dick_landy
    Mar 17, 2007
    82
    i checked the coils and they are sitting in the right spot. i have probably put 40-50 miles on it since. im thinkin it was like that before and just never noticed it. also it seems that the shock on the drivers side(the side thats lower) doesnt have the same damping as the other side. its not horribly bad but if its worn out would that cause that side settle a bit lower than the other? they are sensitracs.
  15. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    A bad shock could definately affect ride height.
  16. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    To check the shocks in the front stand over the front fender and push down with your body weight and relsease. Watch what it does. Does it bounce forever or stabilze in a couple rebounds? Do this again on the other side and see if there's a dif.
    Take a measurment on the shocks- How much chrome rod is showning and compare sides. Oh yea this is 2wd so measure the bottom of the shock to the middle part where it separates (one slides inside the other)
  17. dick_landy
    Mar 17, 2007
    82
    i was thinkin of just unbolting them and seeing if it sits level then.
