try'd wiring it up????
Discussion in 'The Garage' started by Disciples Performance, Jul 5, 2006.
  1. Disciples Performance
    Disciples Performance 1/2 ton status
    Dec 6, 2005
    404
    Kelowna BC, Canada
    hey guys
    so i wired up my autometer 0 - 90 ohms Fuel Level Guage for my propane tank so i dont have to go outside all the time to see how much i have now it kinda works but its not even accurate i have 1/4 tank on the tank guage but on the autometer one it shows just above the E has anyone done another one of these there is only 2 wires on the guage power and ground so i dont know why this isnt working ????:confused:
  2. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    Bump for ya. Are you sure the tank gauge is accurate?
  3. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    im actually not to sure are they very accurate this is my first truck on propane ive owned so i dont really know how well the gauges are??
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I'm not entirely sure but i don't think you can use a conventional fuel guage sender with propane.
  5. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    well its an electric Fuel Level Guage by autometer 0 - 90 ohms i mean what other guage is there possibly?
  6. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Maybe a guage off a propane tank? :confused: Why don't you just get another guage from where you get your bbq propane, tee a line off and run it over to the dash somewhere?
    -Avery
  7. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    Ummm, you need a 0 to 90 SENDING UNIT to work with that gauge.. You can't just hook it up and expect it to work without knowing what sending unit is in the propane tank...
    BTW, some punctuation would make your posts much easier to understand...
  8. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    ah i c well how will i be able to tell what sending unit i have jus take out the guage or what?
  9. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    check ohm resistence when empty and full...
  10. kevcarr59
    kevcarr59 Registered Member
    Nov 9, 2003
    35
    Austin, TX
    It would seem to me the gauge on the propane tank will be a mechanical pressure gauge and not have a sender unit. This would be true if it is mounted by the filler valve.
  11. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    yeah, I have no idea what his tank setup is... The majority of propane tank gauge setups I have seen are cheap inline pressure readings... But I do know they have electrical too, which I assumed he had cuz he was wiring the gauge to it... Pretty sure they have a straight forward arm/float setup mounted at the bottom of the fill assembly...
  12. Disciples Performance
    Dec 6, 2005
    404
    Kelowna BC, Canada
    ya i dunno what kinda sender i have right now all i know is that it was grounded to the tank then a 1 wire left cut? so i thought it would be an electric sending unit ...
