Trying to hook up HEI on an 87...i searched and searched, but still no answer...
Discussion in 'The Garage' started by 01maroonz71, Jan 21, 2007.
  1. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    i'm going to hit the starter to the purple starter selonoid wire in my stock harness, other than that...i can't find 12V's that are only tehre when the truck is in run/start mode...not acc. can anybody tell me a wire in the stock harness that would have this that i can tap into for my HEI dist....once i get that hooked up, she should be ready to start...which is what i wanna do tonight. can anyone help??? i don't have a test light and wanted to get her runnin tonight.
    also, can i fire it w/o headers???? or will it hurt the plug wires in some way????
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    your 87 doesnt have hei? im confused... the easiest way to find a wire that you need is a test light...
  3. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    no...it was TBI and i swapped a carb on her.
  4. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ten4 then... just grab a test light and check the harness for wires that come on when the key is in the run position...there should be a couple...
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is HEI it just has a remote coil not the coil on top of the cap. There should be 2 plugs that the old remote coil would connect to that has your 12v source.
    I will see if I can find a pic.
    Ira
  6. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    The coil is on top of the cap...it's a stock GM HEI off of a different 350, i put a new cap and rotor on it.
    well, here's what i have hooked up so far....the starter has ground and battery, then if i hook up the ignition wire to the starter, that will tell the starter to start...now where does the fuse box get it's power from???? i still need to get that wired up, otherwise nothing will have 12v power right????
    oh yeah, i f'n hate electrical stuff...it's no good.
    here's the best pic of what i've got so far...
  7. goldwing2000
    goldwing2000 Guest
    Power in Run won't do it. It has to be power in Start. Most key-on functions get shut off when the key is in Start.
    Also:
    If you just need to get it running temporarily, hook it to a toggle switch and battery power. Just don't forget to shut it off when you turn off the engine!
    Then drive to the store and get a test light. There should be a wire to the old distributor that was on during start. Disconnect the starter solenoid and start probing wires as you're turning the key.
    Alternately, if you have the solenoid with two small terminals on it, one of them is to activate the solenoid and the other is for power in Start.
    It's ok to start it without headers but don't run it for more than a minute or so. You could burn your exhaust valves.
  8. sandawgk5
    Oct 28, 2003
    6,881
  9. goldwing2000
    goldwing2000 Guest
    You need to have another wire (around 10 gauge and with a fusible link) that goes from the big terminal on the starter (where the battery goes) up to your junction box on the firewall. This is where the truck pulls power for everything and also where the alternator charges the battery.
    It looks like that wire is already there, hanging just in front of the trans dipstick.
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Not so sure about that... my 87's alternator fed directly to the battery...
    original poster.... as goldwing mentioned, the junction block feeds the cab with a fused wire from the starter lug (the fusable link is down by the starter).. in your pic, it's directly above the left edge of your booster, right above the harness, plastic sucker with 2 posts...
    man was I glad to ditch all that fusable link, junction block bs... :haha:
  11. dyeager535
    26,982
    191
    Get or make a test light. You can use a dash bulb (194 or 168) with some wire attached to each terminal.
    The fuse panel will have a terminal you can use, I don't see any reason one of those couldn't feed the distributor. I guarantee one you need (hot in start/run only) will be there.
  12. goldwing2000
    goldwing2000 Guest
    It will work that way, too, but it's not how it's hooked up from the factory.
    Not saying that the factory way is necessarily the best way but I'm not going to recommend somebody cobble together their electrical system. Just cautious, I guess.
    The most important thing is to have the voltage sense lead up at the junction block, not directly from the alternator output.
  13. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    oh, I know it works that way.. I run 4 gauge right over to my marine switch now... but my stock setup had it right to the battery too, iirc.... didn't look like it was tampered with either...
