Trying to identify strange engine noise
Discussion in 'The Garage' started by TrcksR4ME, May 20, 2002.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    My engine seems to be making kind of a ticking tapping sound. It doesn't seem to do it below 1000rpm. A friend thinks it might be a loose rocker, I dunno. The sound seems to be coming from the pass side of the truck.
    If it was a rod or bearing or something like that in the engine, what kind of symptoms should I look for? What would that sound like? I have never heard an engine with a bad bearing or anything so I don't know what it sounds like.
  2. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Check your ex. manifold bolts. Bet it's an exhaust leak.
    Jim
  3. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    The exhaust does leak, and I can hear the valves clicking, but this is different than that, although I suppose it could be some kind of noise from the engine.
  4. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I have three lazy lifters. I got my lifters as NOS. At first I thought it was the head studs were pulling out. Then I realized, I can either make my valves too tight (lost compression) or a little loose and they tap. I will replace them... some day.
    Basically, I ended up checking the compression on EACH cylinder after I adjusted the valves. That's how I found which lifters were going bad. I would run the engine a little bit (to get oil pressure up), then adjust the valves.
    Good luck.
