Trying to install a remote starter solenoid and getting nowhere
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BayouBlazer88, Mar 9, 2003.
  1. BayouBlazer88
    BayouBlazer88 1/2 ton status
    Jul 31, 2002
    353
    Lafayette, LA
    I bought one of those remote starter solenoids from summit to fix my heat soak problem but the instructions it came with suck and now I'm lost. The solenoid has 2 large posts, 1 to the battery and 1 to the old solenoid battery connection. I got that part. Then there are two small posts, 1 labeled "S" and 1 labeled "I". That's where I'm confused, there is nothing in the instructions that says anything about an "I" terminal, so what is that for? Also, do I just attach the new "S" wire (blue wire) from the "S" terminal on the new solenoid to the "S" terminal on the old solenoid? And lastly, what do I do with the supplied red cable? Does that go from the battery to the alternator or something? Any help is greatly appreciated.
    Matt
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    I just put one of thses in a few hours ago here is what I did, The small wire on the starter, I cut and wired it to the "S" terminal, the "I" terminal will not be used if you have HEI, Then all you do is is hook up the main leads and it "should" work, My truck does not have a engine in it at the moment so I can't check to see if I did mine right but that is how I understood the directions
    THE DIRECTIONS DID SUCK /forums/images/graemlins/angryfire.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    "I" = ignition
    "S" = start
    Put a small jumper wire between the big post and the S terminal on the solenoid on the starter. Hook the old start wire (the little one that went to the "S" terminal on the starter previously) to the "S" terminal on the Ford-type solenoid (you'll have to extend it most likely). Sounds like you've got the rest of it correct.
  4. BayouBlazer88
    Jul 31, 2002
    353
    Lafayette, LA
    Ok that helped a lot but I still have one question. The kit came with 4 wires: 1 small black ground, 1 yellow wire which goes to the "I" terminal which I won't be using anyway, 1 blue wire which connects the "S" terminal, and a large red wire (I'd say 6 or 8 gauge). What do I do with the red wire?
    Matt
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I recall correctly, the alternator wire goes straight to the battery. You can either reconnect that to the starter's solenoid (which is what I would do) or run that wire up to the Ford type solenoid. Unless you choose to do the latter, you probably won't need that thick red wire.
  6. OneBBBurb
    OneBBBurb Registered Member
    Mar 4, 2003
    5
    Caseyville,IL
    Hmmm sounds like a debate that started clear back when I used to race stock cars.
    The idea is to get your solenoid away from the heat..correct /forums/images/graemlins/confused.gif
    But all your doing is putting a "switch" in front of another switch. /forums/images/graemlins/confused.gif
    Now..Your starter solenoid STILL has to pull the plunger in to engage your starter.So your hot starter is still working the same as before,you just have another switch between your starter and your battery(more voltage drop,and another system that can go out).. /forums/images/graemlins/crazy.gif
    The only way that that system will work(as they advertise) is if you use a starter from say a "cough"ford"cough" that doesnt have a solenoid mounted on the starter and is mech. engaged.
    That is just my .02,but some food for thought
    /forums/images/graemlins/burb.gif
    Doc
  7. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    Your argument may be valid, but my real world experience with this mod is what I'm going to go by.
    I had a tired and half dead starter that would not turn my truck over once it was even remotely warm. After installing the remote solenoid it would start warm or cold until the starter finally packed it in 2 years later.
    That was my experience with the remote solenoid...YMMV
    Rene
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree with you 100% rene. I have two years of electronics classes and I personally can't justify it with a math equation either, but I can tell you that it works. I've done this mod to a number of boats for my customers and they all have reported good results from it.
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I can vouch for this too, I had real bad heat soak problems when running low speed trails, I put the Ford solenoid in and it now starts up no problem, every time. </font>
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There's one BIG difference that comes into play. With the stock wiring, all of the current to power the solenoid on the starter has to go from the battery, to the steering column, through the switch, then finally back out and down to the solenoid. This is done through 8 or 10 gauge wire, so there's quite a bit of voltage drop along the way.
    Now add the Ford solenoid into the equation. When that sucker closes, you now have power coming directly from the battery, through the Ford solenoid and then directly to the GM solenoid, via a short, fat-a$$ battery cable. The end result is that you can end up with 2-3 more volts, and plenty of current, right at the GM solenoid. That slams it home and away she goes. /forums/images/graemlins/thumb.gif
  11. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    But Evan how heat soaked could it get setting in your garage? /forums/images/graemlins/tongue.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Oh for the love of Mike, why does everyone always have to make the quips about my garage-wheeler? /forums/images/graemlins/rolleyes.gif I ran the remote solenoid for a good year before parking the truck. /forums/images/graemlins/thumb.gif </font>
  13. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Come on Evan, I was just messing with you. /forums/images/graemlins/thumb.gif I wouldn't say anything if I didn't think you were /forums/images/graemlins/cool.gif. /forums/images/graemlins/rolleyes.gif
  14. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I know you're messin with me Bruce. I could give you some $h!t too though... Something about a truck you owned but never wheeled, then sold to a guy who's been driving it 100 miles to club runs... /forums/images/graemlins/grin.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/shocked.gif </font>
