TSB location or part #......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ftn96, Jun 1, 2001.
  1. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, Im getting tired of taking my drivehsaft out nad installing lube or grease to slop my slip yoke clunck.
    Where can I get a look at the GM TSB on this or can someone give me the part # for that Special GM Blue Lube for this?
    Steve Fox for President, 2004.
    Jimi Hendrix was re-incarnated in 1990 as my....JIMI
  2. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Ok, nobody? Come on guys, get that cup of coffee flowing through ya. Wake up!!![​IMG]
  3. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Thats a rog' on the coffee..check your mail. I sent you a searchable database for TSB's. Have ya tried the blue 'marine' waterproof grease?
    "The mud is lovely, dark and deep, but I have U-joints to change before I sleep"
  4. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Nope, haven't tried that yet. I've tried white lith, wheel bearing, some sythethic moly, but no marine.
    Thanks for the E-mail
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    bust out the drill and put a grease nipple on it
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Not bad Idea. How bout I just weld the SOB to the output shaft, and install a 2 piece shaft? LOL!!!!
  7. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's what I did - Drilled/tapped a 5/16" hole and put a zerk in it.
    I'm not creative enough to comeup with a new signature [​IMG]
  8. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Now where abouts it the best place to put it without the ear of the driveshaft knuckle hitting it?
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Mine's about 1/2" above the knuckle on the yoke itself. It's got 3-3 1/2" travel before it will hit anything.
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I may try that. Im jsut looking to buy some time till I get the slip yoke Elim kit. Im jsut getting tired of pulling the DS off every 400 miles to relube the splines
  11. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    What's the effect of all that grease running down into the transfer case? Is it bad? With it affect the fluid in there?
    Ratch
    **<A target="_blank" HREF=http://k5.8m.com>http://k5.8m.com</A> What more is there to life?**
  12. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've never had a problem with it. I use Mystik JT6 High Temperature grease, and haven't noticed any adverse effects.
  13. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I would think that the syntrifical force would keep the grease slung to the rear, well, at least with lowered T-cases. I think Im loosing most of my grease through that little seep hole in the end of my slip yoke. I may try sealing that hole with some JB and see what happens.
  14. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    If your talking about a "clunk" or "shudder" off the line or when comeing to a stop- I know what your talking about.
    I don't know what the tsb# is or The p/n for the grease. But I know the grese is expensive, something like $50 for a tube of it. I think its a 50/50 shot to weather or not it fixes it. So far I haven't had any come back that I know of, but that doesn't mean that they didn't come back and go to one of our heavy liners.
    The grease zerk sounds like a good idea, I like it. I don't think a little zerk fitting would put the yoke out of balence, and if you put it on the tail end of the yoke it should clear. But I think the type of grease needs to be considered. Nothing gritty, like graphites. I think there might be a compatibility prblem with XXXXX (i can't rember the proper name for it, but it is soap based) So that would leave you with some kind of oil based wheel bearing grease or a synthetic grease.
    Pluging weep holes is generaly not a good idea. Weep holes keep the seals from blowing out and let them breath when the get hot. Weep holes (on tail shaft seals) should be located on top, or slightly to the side.
    Twiztid
  15. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    "If your talking about a "clunk" or "shudder" off the line or when comeing to a stop- I know what your talking about."
    This is what Im trying to fix. I'll try the marine waterproof grease next. Then go from there. I should have the money for the fixed yoke kit here in the next month or so.
