TSL,IROCK or SX?
Discussion in 'The Garage' started by jk3078, Dec 14, 2005.
TSL,IROCK or SX
  1. TSL
    24 vote(s)
    24.0%
  2. IROCK
    48 vote(s)
    48.0%
  3. SX
    28 vote(s)
    28.0%
  1. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    New skins for the sub-buggy!!! Just looking for input from any one runing these tires. I'll be buying 36s next month with the taxes. Whats the best for rocks mostly ,trails and some mud? Side wall durability? The IROCK'S look bad ass and thats what I'm thinking i'll get, but I figured I'd get yalls 2 cents before I laid the cash down. O and this truck will see no street use.Not enough trucks up here in po-dunk to see all these tires in action much so any info would be cool! Thanx.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
  3. chopped&bobbed77burb
    chopped&bobbed77burb 1/2 ton status
    Oct 5, 2005
    925
    milwaukie,oregon
    I vote Iroks
    I had the 36" Iroks on my burb before I went to my current 42"tsl . The Iroks rode nice and kicked a$$ in the mud and snow . They did well on the rocks too. They do balloon out a bit even on a 15x10 rim And the big plus is they are fairly cheap for a 36" tire (bias ply) . I mounted the tires my self with tire irons & the starter fluid method + I never had them balanced & they never needed it . I would have went with the 42" Iroks but they don't have the tread depth of a tsl and I think the sidewalls are a little thicker on the tsl . My burb is a heavy pig so I want a stout tire under it . I will be running a set of Iroks on my jeep cj5/buggy when it's ready .
  4. kotton
    kotton Registered Member
    Sep 1, 2004
    64
    Orange County, California
    This guy isnt lieng about the rode manners. I Just got some 36" biased IROKS at the beggining of this week. I have yet to take them offroad but they are damn good on the road. 4 of them only ran me about $800 mounted and balanced.
  5. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    IROKs! Here's a shot of some sidewall flex. I ran 6 lbs on this trip and this is an example of the punishment I gave them. I had no problems at all during the two day trip!
  6. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    at that size, a TSL shouldn't even be on the list. The SX has the added value of side wall lugs. Either the SX's or the IROK's would be the way to go. The IROK is a stickier tire, but at the cost of tread life.
  7. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Definately the Irok, probably the best tire in the 35-36" tire range, and they are a true 36" tire. Since you say it will see no street use I wouldn't worry about tread wear.
  8. kmodi
    kmodi Registered Member
    Nov 9, 2005
    56
    Atlanta GA
    what about at 42", do you think the irok is still the best choice?
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Even better choice. The tread depth of the 42" irok is VERY close to the tread depth of the TSL. So that really cant be a deciding factory. The Iroks grip SOOO much better then TSL's.
  10. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    There is a 36x12.50 tsl on the market. Ive looked on Intercos web site and know the specs on these 3, so the choice is down to performance. I'll be mounting them on 8'' wide wheels so mabey that will suck the side wall in a bit. thanx, as allways very cool!!
  11. rodney chambers
    rodney chambers Registered Member
    Jun 23, 2005
    50
    northeast oklahoma
    i run 35x15.5 sx on the bluggy. i love the traction but they are just a bit short.
  12. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I'll be the oddball and vote for SX's. I don't care for the lesser tread depth of the Iroks, and road manners are not an issue on my list. I love the SX over the TSL's I had before.
  13. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    If you are looking for the best in sidewall strength, then SX's. I do like the IROK but have never ran them myself, but have had heard nothing but good things about them from people I know who are running them. I run 36 sx's and once they break in (at first they were really stiff with 4 ply sidewalls, wouldn't even flex at 10 psi at first) they flex really well and do very good on rocks. Have rapped the sidewall with roots and sharp rocks and pinched them badly with zero problem. I am starting to think "why did I buy a fifth one as a spare."
  14. BIGRED74K20
    BIGRED74K20 Registered Member
    May 23, 2005
    82
    23
    Northwest
    i would not run the iroks, i bought the 36x13.50 iroks when they first came out and ive had nothing but problems with them. first off after 500 miles on them the insides were falling apart, i mean i got a handfulls of rubber out of them. so i had to warranty 2 new ones and had to pay to get them balanced and rotated. second of all they wear down really fast, my boggers lasted longer then them. and it seemed like every other month you had to dismount them to take the rubber out. plus the traction sucks unless you drive around with 13 psi like i do. and all of the the outer lugs are half gone or chewed up from wheeling. IROKS BLOW
  15. jk3078
    Nov 12, 2005
    374
    Moyie Springs Id.
    Anyone else hear of or have these proplems? Sounds mostly like on road use caused which is no place for a bias tire anyway really. As far as chunking or lugs being torn off this sounds like full throttel attacks on sharp, rocky trails. Not really my style except as a last resort:D Every set of tires I've ever used offroad had some chunking which is to be expected out of soft tires used hard on tough trails. Any more .02 anyone?
  16. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    Looks like someone should have been running an AT. You have to expect some chunking on a tire are soft and sticky as the Irok. And 13 psi on a chevy 3/4 ton full bodied truck is way soft so the heat from that probably has something to do with his inner carcass failure.
    I have had about 10 sets of Iroks go through my club and nobody has had any issues nearly as bad as this guys. The issues I have seen are balloning with the bias plys and boht versions running larger than other swampers. We had one member go from 39.5 bogger to Irok and he ate his fenders up with the Iroks on the first trip. He had runn boggers for a couple years and the fenders were clearanced accordingly. Another guy went from the 36 TSL to a 36 irok bias and same thing fenders were nolonger wide enough.
    I am going to run Iroks for my next set once the TSLs are done. That could be a while with my engine currently in the basement :doah:
  17. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i really like the iroks except for the tread depth for the 39.5"
  18. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    I'll vote SX's. I run them on my 1 ton k5 at about 9 psi on the trail, and I absolutely love them. There are plenty of rocks on the trails here, and I have been very pleased with their toughness. I slammed my left rear into a rock the other day hard enough it nearly pushed it off of the bead, and it just grabbed the rock and up I went without even a nick on the sidewall!
    If there is one bad thing about the SX's, it is that they make the mud holes that used to be a challenge boring because now I just idle through them.
  19. stayaway
    stayaway Registered Member
    Aug 1, 2005
    59
    georgia
    I have iroks and love them :D
  20. TX_GLADIATOR
    TX_GLADIATOR Registered Member
    Sep 21, 2005
    60
    San Antonio TX
    44'' tsl's for me
