TSL on front Boggers on rear
Discussion in 'The Garage' started by crazyrc, Jul 9, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    Right now I've got 39.5 boggers. Thinking about trying TSL on the front instead of the boggers. I've heard this is a good setup for mud running.
    Or should I step up to 44's. TSL in front...boggers in rear. Will 44's suck with 4.56 gears?
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    yea 44"s with 4.56s will kinda suck. i dont know wat kinda advantage it gives u to run different tread designs front and rear. i think it looks dumb but thats jus my opinion.
  3. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I've seen/heard of that setup. IIRC, the TSL's have better lateral stability, so having them on the front makes for better steering, while having the boggers on the back gives you the push in nasty mud.
  4. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    A guy at the local mud races runs a setup like that. He only runs 33's though. Does does alright. I've never talked to him, but I've heard that the TSL's on the front give you better steering.
    Kris
  5. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I've seen quite a few guys run that setup around here, mostly on jeeps though. Most of them will run a skinny TSL in the front and a big ol' fat set of boggers in the rear.
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    a friend that wheels w/ me runs that set up in the 44" flavor. it works good in the sloppy. tsl's will out-steer boggers & also come up out of rutts better IMO.
  7. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    there are a few reasons i run this setup...
    Steering has already been covered.
    Width.. i can steer sharper with a skinnier tire in the front 15.50 instead of the 18 bogger.
    Ruts, the front tires will make their ruts a little narrower, so the outside of the lugs on the rear will have fresh goo to grab a hold of...
    i think it looks kinda sweet myself......
  8. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    no pics? /forums/images/graemlins/eek.gif
  9. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    there are a few pics in my sig line nothing great. should have some pics of the sand in awhile.....
  10. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    4 wheel and off road say's that boggers on the front causes it to dig in to much due to engine weight. because of the cupped tread. i have them but haven't used them yet. ( yea i'm the idiot with $1000.00 tires on a DD), any way their reason sound's leggit to me. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have run both ways with 39.5" tires and heres what I have found.
    Boggers all the way: The best traction and can easily steer out of ruts. A good way to go for the worst mud.
    TSL on the front: Easier to steer, less strain on front end stuff. Can be harder to get out of ruts with. I run the mixed setup quit a bit as it rides much nicer. I will still run boggers all around if I know its going to be bad though.
  12. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    I did this (on my Jeep with 39.5s) for the simple reason... big Boggers break parts. Period. And TSLs are much easier on parts. And at the time I only have a 10 bolt front. And it last nicely with the TSLs.
    Ken H.
