TSL Sidewall Break-in, How to get it done quickly?
Discussion in 'The Garage' started by FWP, Sep 27, 2006.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    The sidewalls are super stiff right now. I need to go wheelin on Sat in a local Comp. What would be the fastest way to loosen em up? I was thinking of driving around the neighborhood on 3-5 psi for a couple of hours:crazy:
  2. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    201
    Colorado
    A few years back we had to do the same thing and did a 20 mile drive at wheeling pressures. It kinda worked, maybe try really low pressure and drive down a curb with half the tire on the curb and half off??
    Good luck.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    run them flat around the block. They will be SOFT.
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Hey Fred did you just go with a set of 42 TSLs? Did you change rim size or still running 15s I saw you selling your old rims. Oh yeah where are the pics:D
    Ira
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Drive them at about 5psi or just before the sidewall starts to pinch (You can over soften them if the sidewall pinches itself) for 15-20 mins, let them cool, repeat. It is the cycleing that makes them soft not the flexing.
