tsl swampers what psi for street use
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mudhog, Feb 23, 2002.
  1. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i just got a set of 38x13x16in tsl swampers and was wondering what psi you all run on yours i was told to run it at about 28psi on the street what do you all run?
    wheeling pics
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I ran my 35" BFG's at 28 on the street. I looked at the swamper website and they only list the max pressure which is 45..I don't even inflate my trailer tires to that much,LOL
    Anything around 30 would be good IMHO.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  3. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    28 psi seems to be about right but to be sure you can do the chalk trick. Run chalk out to the farthest part to the outside of the tread then roll around to see if it all rubs off. If not you need to go lower and... you get the point.
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
  4. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    I did what Chad reccomended. Mine are 35x14.4x15 SSR's, they ended up at 24 psi. I think that low of pressure is because they are so wide. I run 20 miles to work, they don't even get warm. Handles pretty good.
    Later Ed
    I'm not tail gating. I'm DRAFTING.
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Well, it all depends on the weight of your vehicle. You can use the use the chalk method or divide the total weight of the truck by 4 and that is the load that each tire is handling. Then compare that number in relation to the max load of the tire. So if it is handling the max amount of the tires recommended load then you would run the max pressure. You have to figure the percentages. Hope I didn't confuse you. [​IMG]
    Its the popping, rumbling, roaring, twisting, flexing, grinding, so you can wheel anywhere medicine[​IMG]
  6. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    I guess I'm the only one around here that runs my TSL radials at 32 psi?!!! The way I figure it (just by my own experience and knowledge) is that at that psi, my tires have worn evenly. Not so much the front ones, though. I ALWAYS run mine on the street as it is my only vehicle. The rear ones have worn perfectly-even at that pressure.
    <font color=red>"PROCRASTINATE NOW!!!"</font color=red>
    <a target="_blank" href=http://coloradok5.com/gallery/BigTex-Mean-Machine>http://coloradok5.com/gallery/BigTex-Mean-Machine</a>
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I run my Radial's at 30-32 psi.
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda>I'm Discombobulated </a>
  8. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    28psi is too much for 38" tall tires.
    You will get better wear and much better ride below 20
    I have 38x12.50 on my long wheelbase. I run 16psi on the street. They are wearing great, and the ride is great for a truck this tall.
    BTW, 32psi made my 30x9.50" BFGs wear in the center, imagine what it will do to your Swampers
    Over 600 posts and still a "pavment pounder"...
  9. ChadH82
    May 9, 2001
    400
    Then your gas milage drops to zero. There's a happy medium in between there somewhere. At 16 psi your probably making up for making your tires lasting longer with the gas money.
    Chad
  10. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    How would you know RedDwarf, you are still a Pavement Pounder.[​IMG]
    4 wheeling is like sex, when its good, its really, really good, when its bad its still pretty good.
  11. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    39.5x15 16.5 I run 22 up front and 20 in the rear
    Eat More Mud!!!
  12. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I run 39.5x15-15 Swampers @ 20 psi. This seems to be a happy medium.
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs, ORD crossover steering
  13. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    You have a legitimate point. It's not the pressure in the tire that supports the weight of the vehicle, it's the volume of air in the tire. That's why the bigger the tire is, the less air pressure is required to support the same weight. 30 psi in 31x10.50 tire is a lot different than 30 psi in a 38x12.50 tire. The pressure, which is correlated to volume, of the tire is just the easiest way to measure what is in the tires.
  14. RedDwarf
    May 9, 2001
    816
    "How would you know RedDwarf, you are still a Pavement Pounder"
    That's "Pavment" pounder to you! [​IMG]
    Just tellin what I have found to be true. Nearly every person I know who has big tires runs way too much pressure in them and their trucks ride rough and you can see that the center of the tread is lower than the rest.
    Mine on the other hand are wearing even and ride good (except they're not round [​IMG])
  15. Blazr77400
    Aug 31, 2001
    652
    Ogden, UTAH
    I had 20 psi in my 39.5-15-15's and that was too much. Just went down to 16 psi. Hope its good enough. Might have to buy another car so my tires last long enough.
  16. HighSierra
    HighSierra Registered Member
    Jul 19, 2001
    19
    Nazareth, Pa
    Im my 33" radials I run 35 psi in the front and 33 psi in the back. I ran 33 psi all the way around at first but the tires wanted to roll over them selves to much. The truck rides and corners like a dream.
    If it aint broke, Keep fixing it till it is.
  17. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    all my 36x12.50-16.5s are at like 38 psi, is that too high?the sidewall says 45psi. they're bias-ply TSLs.
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
    <a target="_blank" href=http://community.webshots.com/user/muddysub>http://community.webshots.com/user/muddysub</a>
  18. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I talked to Scott at Rockstomper today and he has 44" Boggers on the back of his Toyota. Street pressure in them is 3psi and trail pressure is between 1/2 and 1psi. I run 34 in my 35's on the street.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
