Tub Swaping
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blaznjon, Jan 12, 2005.
  1. blaznjon
    blaznjon 1/2 ton status
    Mar 6, 2004
    153
    Seaside CA.
    I live a half mile or so from the ocean and The body on my 76 Blazer is rusting away by the windshield to the point that if I put her on her side one more time the roofs going to fall off.I no somebody here must have swaped different year tubs before. Whats the difference in frames ,mounts between 73-89 blazers?I know that there are different body mounting bushings for the different years.And that newer blazers have a different floor by the back seat.Can I put just about eny of those year bodys on my frame by changeing body mounting bushings?.Or would a newer then 76 ,80`s blazer tub not clear the frame around the back seat area.Enybody done this before? Thanks Jon
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Anything is possible if you want to fab up/move bushing mounts. But the easiest way your going to have is to swap tub with a tub of the same floor layout. I don't know exactly when that changed tho.
  3. blaznjon
    Mar 6, 2004
    153
    Seaside CA.
    Thanks,I was afraid of that.I guess its time for more cutting and welding.Jon
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    You'll more or less be stuck with a 73-77 tub if you keep that frame. In 78 they added the rear passenger footwell, which also required that the frame be different. If you try and put a 78 or newer tub on that frame the footwell will hit your current frame rails and not allow the body to sit down on the frame.
    A 77 or older tub, or a 78 or newer donor frame and body would be your best bet. Mixing and matching also leads to hand fabricating the body mounts right behind the front seats (mid body or #3 position)
    Rene
  5. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    tub swap
    Rene is right, I have a 1977 blazer under restore now and a 78 waiting for fabrication.
    The body of the 77 was crap so I cut it off the frame with a disk cutter and litte did I know that the 78 body was not going to fit due to the mounts being different so I got stuck with two blazers with different body/frame patterns, your best bet is to check the junkyards in your community due to the fact that your near the ocean or the classifieds too, thats how I found the 76 4x2 for $500.00 with a good sound tub with no engine.
    Check around your state you may get lucky.
    Mike
