tube body legal
Discussion in 'The Garage' started by TXFSHRMAN, Jun 30, 2005.
  1. TXFSHRMAN
    TXFSHRMAN Registered Member
    Jun 22, 2005
    22
    DEER PARK, TEXAS
    does anyone know if you scrap all the body panels from the rear quarter panel back and go with a tube body if that is street legal keep in mind i want to keep my rear seat...has anyone done this and would it be legal?
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    i would imagine it wouldn't be much different than a flat bed..as long as you had the proper lighting, and mud flaps to cover the tires you should be fine. i know guys that drive pick up trucks with no bed at all on..just the cab and bare frame..they run mud flaps and trailer/tow lights on the end of the frame...check your local laws tho
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Depends on the local laws. Better check with DMV/DPS unless you are sure.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    The problem is a K5 is not a pickup truck. It is considered a wagon and the rear area is passenger space. You could probably tube it but I bet to be road legal you will have to skin it (maybe make removable panels). I know, at least around here, you can't run a K5 without the tailgate. And a turbo net doesn't count.
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i never once got hassled with this by the cops.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    In the 70's (including 2nd gen) they sold K5 with no top, no back seat and no passenger seat if you wanted, just one seat for driver and that's it. I don't see why it would be illegal to run a k5 without a gate. You sure about that. Mabey the cops are just giving you a hard time.
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    from what I've seen cops in texas don't care about much of anything unless you piss them off
  8. poinzey
    poinzey 1/2 ton status
    Jun 16, 2004
    113
    Texas
    Double check with the dmv in austin just to be sure....but I seem to remember there being something about there being a rear bumper a certain height off the ground. Other than that tail lights, mudflaps, license plate, and I think you're good to go. :)
  9. resurrected_jimmy
    May 23, 2005
    2,241
    IIRC, bumper height in TX is 58" and there is a headlight law, but not sure about taillights
  10. oldassjeep
    oldassjeep Registered Member
    Oct 21, 2004
    84
    Burnet TX
    Here you go.
    http://www.capitol.state.tx.us/statutes/tntoc.html
    Texas Traffic code. Got to chapter 547. It will cover what is legal as far as light heights, approved bumpers etc. I have not found anything in it regarding tube exo-cages nor the operation of the vehicle without a tailgate. The K5 would have to have a tail pipe that exits behind the rear seating compartment. Meaning behind the rear seats in order to carry occupants. (because it is supposed to be enclosed.) Other than that you should be fine except the cage can not extend greated than 6 inches from the widest portion of the body. If you remove the body skins though????
  11. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Around here ie. the state of Pennsylvania we have safety inspections. Some of the rules I am familiar with deal with passenger compartments and the classification of the K5 as a wagon and not a truck. Did you know in PA a cars trunk is considered a passenger compartment because there is no firewall behind the back seat? So any holes in the trunk floor must be patched so no exhaust gasses can leak into the passenger cabin. If you have an open cab K5 (not a truck cab conversion) the whole thing from firewall to tailgate is considered passenger space wether there are seats there or not. And since passenger space requires enclosure on all sides you cannot run without a tailgate. You also cannot run without doors unless you put a panel in near the floor like the jeeps have.
  12. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    Do you even need bumpers at all?
  13. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    yes, again I know in PA you do. Unless your vehicle came factory with a no bumper option which means most trucks do not need a rear bumper. But they do need a front one.
