Tube bumpers as airtanks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, May 2, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Does anybody use tubebumpers as airtanks and if so how much air can they hold. Can you fill a 33/1250 tire?
    IFS - Just say no!
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I had a friend that made one out of 6x8 tubing across the back of his truck. First off you have to be a very good welder since any little pinhole will create a leakage problem and your tank will bleed off in no time. You might be able to fill a 35" tire or two. But imho, it's not worth the hassle for the gains. on board air, co2, or just one of those red tanks is so much easier and better. Now the bumper tank coupled with on board air deserves a little more thought.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    It could be done, but I don't think anyone would make them. That is a HUGE liability issue. Using a tube bumper as an air cylinder is risky. You would be putting a high pressure piece of equipment in a prime area of impact. Not to mention, It would have to be a huge bumper to hold much air. If you want air on the trail, just by a portable air cylinder. It would be much cheaper anyway. It would be expensive to have a shop make you a bumper/air tank. The testing that stuff has to go through to get certified is a PITA!
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    SEC makes that option. Do a search WAY back - we have discussed pros and cons at length. I am all for it since it is relatively low pressure.
  5. laketex
    6,220
    North Texas
    You really classify 130 lbs of pressure in a 1/4" thick tube as risky??? If someone rearends ya hard enough to rupture that, you'll have a lot worse problems to worry about. CO2 tanks run much higher pressure in a much thinner tank.
  6. laketex
    6,220
    North Texas
    here's a really good writup on a air tank bumper.
    <a target="_blank" href=http://billyxj.tripod.com/rearbumper/rearbumper.htm>http://billyxj.tripod.com/rearbumper/rearbumper.htm</a>
  7. I called SEC about 2 months ago and they said they no longer offer this option. Later 80K20
  8. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    Bad Link? /forums/images/icons/frown.gif
  9. laketex
    6,220
    North Texas
    works for me.
    Just has a TON of pics...may take a while to load on slow connections.
  10. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    Yep now it's working...
    Thanks, Shane
  11. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    blazer72 uses his sliders as airtanks for his onboard air. holds enough to run air tools. I've heard of bumpers being used too.
    Chris
  12. BIGRIG
    Feb 29, 2000
    488
    Independence, MO
    Chris
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    wonder why?
  14. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    I agree, its not that big of a deal..
    I think that using a tube bumper for on-board air is a xlnt idea. I dont know about using it as a storage tank though.....
    mike
  15. Grim-Reaper
    7,385
    Atlanta
    I put 150 PSI in my rock sliders (4x4 inch 3/16 wall). I bash the hell out of them and haven't had problem one. I can fill 4 32x11.5 BFG's from 20 back up to 34 psi (tire is rated 50psi max and I ran then about 34 on the street). Just put the 35's on. Tire has a lot more volume. I can only go from 18to about 26 PSI. Enough to get to a gas station to top off to the 30 PSI I run on the street.
  16. bajaviking
    Apr 10, 2002
    752
    Baja
    If you have time could you please let me know what kind of couplers and parts you used, I am really interrested in doing something like this. I am a pretty good welder but I have never done anything like this.
    Thanks.
  17. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Ok, I'm only gonna say this once... I STAND CORRECTED! /forums/images/icons/smile.gif!! learn somthing new every day.....
  18. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Would you run these bumpers pressurized on the street? I'm thinking thats a bomb in the event of a crash.
  19. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I saw plans to make an air tank out of a roll cage, that would hold alot more air, but all in all i think just buying a tank would be the best bet, rather be safe than sorry.
  20. Grim-Reaper
    7,385
    Atlanta
    I don't see it any riskier then running them on the trail. I drop off ledges onto granite rock all the time. The front of a car is more forgiving than rock /forums/images/icons/smile.gif Cars are made to crush.
