tube dash latches/sealing
Discussion in 'The Garage' started by 84gmcjimmy, Jul 31, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    This is the second time writing this, previous time the internet closed /forums/images/graemlins/mad.gif
    When I build my rollcage I want to incorperate a tube dash that will replace the stock dash completly. This won;t happen for a while though... but I have some questions...
    I am going to incorperate 2 comparments; one for light switches, and one for ignition box/EFI computer.
    Since my k5 won't have a top, these need to be water tight and sealed from water, snow, mud, etc.
    The reason why I want the light switches in the comparment are so the dash isn't so cluttered (eventually I want a bunch of lights, so when wheeling at night... etc) so when I want to turn on the rock lights or something, I would just flip open the compartment door and flip the toggle switch.
    Light switch comparment:
    I want the door to open towards the rear of the k5. It has to be water tight like I said. But I don't have a clue on how to latch it, or seal it. The latch has to be easy to operate, and whatever else a latch does.
    Then for the ignition box/EFI computer thing, I would make it over the approx. spot where the old glovebox was. It would have the door open towards the rear like the other one. And it also has to be water tight against rain, etc. And I need a way to latch it too. Any ideas are welcome...
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Wire them into ammo cans and shove em up your ass !
    I have no idea why I said that
    Anyway, maybe use some ammo cans for a center consold and throw all switches in there
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    So do you want something like this?
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    bullet,
    it will be simular, but it will be my own deisgn. Since his is tested and true, I will use some ideas from his.
    Mine will be different, and not as "beefy", as watson is more experienced than I.
    Mine will also be completly water tight. The whole dash...
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    anyone know? Maybe something like weatherstripping for sealing? I don't know /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  6. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    why not use rtv? don't need no stinkin weather stripping! how often would you be taking your dash apart anyway? with rtv you could 'proof some wacky shaped stuff that might not work very well with pre-made-for-other-applications weather stripping.
    just an idea,
    j
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    oh sorry, I should be more specific... I will be using RTV silicone stuff over top of all the seams. But I was wondering what I can use for the compartments sealing? Since they will be opened and closed everytime I work on it/go wheeling at night.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    wouldn't it be more efficient to use water-proof high zoot switches (use whatever they use on boats) for your lights and have the housing the switches are mounted to sealed with rtv? /forums/images/graemlins/grin.gif
    j
  9. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    It shouldn't take much. I'd try some weather stripping with adhesive on one side. Your gonna want to have a lip/channel to divert most of the water around and away from the seal area for the best results.
    As for the sealant suggestion, I wouldn't use RTV. Use 100% silicone. I've herd of engine builders using this instead of RTV in non-high heat areas.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I want a simple looking dash, not something with a bunch of switches, so thats why all the lights except main front and rear will be in the comparment. On the outside I will use marine switches so they are okay if they get wet. And the comparment will probably just have normal toggle switches if I can get it sealed good.
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a local rv/camper place should be able to help you out. i know we have TONS of different seals avaliable at work.
  12. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    could just bulid it how ever you want mostly water proof and just soak it with ignition protection or water proofing spray every once and a wile.
    you building this rig (eventualy) for rocks right? so your not planing full on water crossongs and stuff right? just open to the elaments, spray would do a lot , its helped me and my buds on a lot of water so...
  13. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'm building this rig for rocks, mud and trail rides. Thats why I want it to be waterproof-mud. And also its wet half the year where I live. So like I said, without the top on, it's going to get wet.
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll probably just use weather stripping for sealing.
    What about latches? Anyone have ANY ideas?
