Tube Doors almost finished
Discussion in 'The Garage' started by Butch, Aug 11, 2002.
  1. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I am almost done with my tube doors other than mounting the hinges, striker, and cover plates at the fender. Go over to my web site and take a look www.BentandTwisted4x4.com Look on the coming soon page. Should be finished before the end of the week. They will also turn off the overhead light when shut. Feed back welcome
  2. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Where is it hinged at.I see the stock hinges aren't being used.Or will they use the stock hinge mounting holes?
  3. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    The bolt holes for the stock hinges will be used with a barrel hinge set up that will open to 135 degrees so you can get in the truck from the front which is very helpful when twisted up in the rocks.
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    First off those are the sweatest tube doors yet!!! What is an approximate price for them?
  5. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i tried your message board on your site and something weird was going on /forums/images/icons/confused.gif
    anyway, i'll just ask you here.
    i was wondering if you could (maybe as an option) have a different design for your top bar??? something like an angle.
    here's a pic to show you what im talking about.
    i hope it's ok to use your picture as an example /forums/images/icons/grin.gif
  6. BOWTIE
    Dec 28, 2000
    2,018
    /forums/images/icons/grin.gif /forums/images/icons/grin.gif BTW these are the best tube doors iv'e seen so far. /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  7. blublaz57
    blublaz57 1/2 ton status
    Feb 2, 2002
    175
    aarizona
    very nice i want a set ,cant wait until they are for sale
  8. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    The ones I am doing for Fox will roll over almost 180 at the top and come into the horizontal bar to be lower. I could do like you have drawn it but I thought it would be uncomfortable to lay your arm on.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I built something similar for my buddy last week, don't have pics yet but it looked like this...
  10. CK5
    May 19, 1999
    21,623
    701
    CO
    Tim
    Can you make mine like this, the black area at the bottom is the steel mesh part, I really like the look of the angles, what does everyone else think?
  11. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think I like that idea even better. Easier to put your arm on.
  12. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Could add a flat surface to the top edge (armrest?) and a cupholder near the hinge area? /forums/images/icons/smile.gif
    I don't know if anyone would want those things, but they could always be "options".....the armrest one seems like a good one....I'll bet once the doors are removed, you spend a lot of time trying to rest your arm (out of habit) on the non-existent window frame!!!
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats a good idea Steve, what were those on?
    You only need the first half of the door to be flat for your arm to fit and then having it rise up makes for a good handle as well.
    If you wanted to be really slick with them, make them hinge at the bottom and fold down as steps! /forums/images/icons/wink.gif
  14. cojnit
    cojnit 1/2 ton status
    Jul 23, 2002
    178
    Hawthone, CA
    I will echo the group thought...these are the best doors around. Target price for a '76 k20 pickup? I would like to see the armrest option, you can pad it yourself. also maybe some kind of quick release system that you could attach to your stock hinges and your stock door for quick mounting. I saw these for some fiberglass doors for a t*y*ta, pretty pimp.
  15. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    I can run the tube down that low, but right now it is 1" lower than your door is. If I put it that low you will be leaning down to rest your arm on it. I dont think the kidneys would appreciate it but if that is what you guys like I will make a set that way and have you look at them. I expect the price to be in the high 200 range plus any extra options like the swing out mirrors.
  16. cojnit
    Jul 23, 2002
    178
    Hawthone, CA
    I was thinking maybe split the difference between the window sill and the armrest inside the cab. The armrest is low enough to just rest your elbow on and still drive and the window sill is a liitle to high to be comfortable, wow it would be nice not to have the lock poking me in the bicept! But maybe that is just my pick-up, I dont know about the blazer.
  17. Jeff427
    Jeff427 1/2 ton status
    May 22, 2000
    1,186
    Gladwin, MI
    Hey Tim, you should have Steve set you up with a Bent & Twisted forum in the aftermarket section, here on CK5 along with ORD /forums/images/icons/smile.gif.
  18. SummitXMK
    SummitXMK 1/2 ton status
    Jun 6, 2001
    141
    Idaho
    I would have to agree that I like the angles that Steve showed in his green version but I also agree with butch that I would want the top tube to be more like my regular door to rest my arm on.
  19. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    We have been talking about that. I think it would work out nice, just got to iron out all of the wrinkles
