Tube for roll cage?? what to get?
Discussion in 'The Garage' started by sled_dog, Oct 17, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    A friends uncle is gonna get me tube for my cage project. Also gonna get me stuff to put on rocksliders and all but I want to know what should I get for my cage? 2" tube? what wall thickness?
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i'd go 1 3/4--.120 wall
    or if you like the big tube 2" .090---.120 you'll have fun bending
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Make sure you get DOM tube for a cage, HREW is not strong enough. The HREW will work for sliders tho /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    in that area I am going with 4x2" rec tube with 2x2" square tube supporting it all to the body. A little boatsiding.
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">explain exactly why
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    HREW will be fine, IMHO. Alot less expensive and in the thicker wall tube it will be no problem. I'm no expert, but from everything I've read this is the case.
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Ignoring wall thickness.....HREW is a seamed tubing, DOM is not. More impact strength with DOM
  8. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I guess it depends on what the truck will be used for, but in rockcrawling, most rollovers will be very slow, so impact strength isn't as critical as ultimate tensile strength. Like I said, not an expert here so I could be way off.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Evan, I'm no expert here either, I'm saying what I was in a big conversation about with a metalirgist(sp?)at work a few months ago
  10. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Seems to be a case of two people argueing second hand knowledge here... I'll shut up now and wait for the experts. /forums/images/graemlins/tongue.gif
  11. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif I agree
  12. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Dom is a lot stronger than hrew tubbing.Go with the good stuff after all the cage might save your life someday.
  13. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    deleted dint want to hijack the post
    69k5
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ok, first, to clear up a few things.
    DOM *IS* HREW. It's just HREW with extra work done, like drawing over a mandrel. This drawing eliminates the inner weld ridge, provides tighter tolerances, AND work hardens the tube a bit. The work hardening is the only difference in strength.
    What most people miss is that DOM is usually a different alloy. DOM is usually found in 102x (mine was 1028 for my steering rods) and HREW is usually found in grades around 1010. The exact grades stocked depend on the industries in your area and their needs. This also makes a difference in strength between HREW/DOM.
    As for size, 1.75 x 0.120 in 1010 HREW is generally considered the best compromise of size/strength/weight ratio for a full size K5 trail/rock rig. That is what mine is built from. If you plan on beating the shnit out of it, rolling rather frequently, and smacking things a lot, then you probably want a 102x DOM cage of the same size since it is stronger as well as bit more abrasion resistant. However, IMO, for the vast majority of the trucks, DOM would be absolute over kill.
  15. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    And a little tidbit on the whole cage thing, the focus of building a cage is in design. Doesn't matter what it's built out of (well it does) but the design of the cage is very important.
    And last but not least, screw the HREW and DOM, go Chro-Mo /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  16. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'm thinking I will get a locl junkyard that bends cages to do my main bar. Maybe my over door bars too. I'm just going to have a main hoop inside the top, then 2 bars running back to the frame(probably meeting the frame near the middle of the back fenderwells), and then the two bars going over the door frames and down in front of the dash. There will be a brow bar across between the 2 door bars as well.
  17. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Absolutely!
  18. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    And to add one more little to the rollcage discussion.
    Someone like me who has a welder and bender has absolutely no business building a cage with what skills I have. It definately takes someone who has the knowledge to design, then weld the cage up. I definately would not go into a first bending and welding project building a cage.
    Make sure whoever is doing the cage knows WTF they are doing.
  19. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Hmm its not my first bending and welding project. That was my bumper. But that showed me I'm not very skilled to do it. I'm thinking I am gonna load the K5 on the trailer, and drag it over to that junkyard and have them do the cage. Shouldn't cost me too much. They charge $2 a bend I think on exhaust not sure about cage. I will just have them do the main bar and door bars probably. Everything else is straight tubing. You know with my dad's help I may be able to do it just fine. He has raced dirt track cars with cages he made for years. Has rolled a few and worst thats happened is body damage and bending a few cages bars that he just replaced.
  20. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    If they are using an exhaust bender to do a cage stay away. Me personally, (if not doing it myself)I would drag it over to Otter's shop near Harrisburg. I saw the extremely bad roll he took during Neuroc on video and then looked at the cage in person, it held up flawlessly.
