tube sizes.
Discussion in 'The Garage' started by g-wizz, Apr 27, 2006.
  1. g-wizz
    g-wizz Newbie
    May 10, 2005
    4
    sandiego, ca
    well this is a very general quiestion so ill try to make it more specific. the quiestion is what size tube will be suitiable for a roll cage, it will be dom of couse, but what size. i plan to build a buggy i have access to a bender with a 1.5" die. i can buy a bigger die. so what are your thoughts. i plan to make the blazer at least a foot narrower, and hopefully alot lighter. as in no roof glass interior jive. but it will probablly end up being heavy. oh and i plan to roll it alot.
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    If you are at all doubtfull about your engineering skills use bigger tube. Like 2".
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I will be building my cage out of 1- 3/4 in DOM.
  4. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    do a search, you will find a ton of discussion on this subject.
  5. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    i am using 2 inch DOM for my exo cage and flatbed frame, with lots of bracing and gusseting. i think it will hold. i am a master welder of sorts. everything but tig.
    camokrawler
  6. g-wizz
    g-wizz Newbie
    May 10, 2005
    4
    sandiego, ca
    im not to doubt full of my engineering, i do plan to use alot of triangles. and what not. like i said i realized that my quiestion is very vague, i may just buy a 1.75 die for the bender, but that still leaves me to choose what thickness of tubing. i just wanted to know what people have used and what works and well dosent. what im building will not be the same size as a fullsize, it will have d44front gm 9.5 rear. dana 300,700r4 sbc and link suspension front and rear. i plan to run 37s with superiors and ctm. but as of now i have a severe time crunch and basically the faster i start welding and making the main frame the better off i am.
  7. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    1 3/4 .120 wall DOM is what I would use. some guys dont like the extra cost and use .120 HREW tube.
  8. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Well, I've used 1.5" x .120 wall HREW tube on 2 rigs I've built - this one being the latest:
    Marv
