Tubing Benders....
Discussion in 'The Garage' started by RustBuket, Oct 6, 2004.
  1. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Well, I'm thinking about trying to make my own tubing bender so I was looking at a couple on ebay for ideas. However. I came across two different sorts of dies...
    one is with a center hinge point and one without...
    With Hinge
    Without Hinge
    Which type of die is more common? Which is cheaper? Which works better (advantages?)... Just trying to collect info to make the design a whole lot more concrete. /forums/images/graemlins/thumb.gif
  2. RustBuket
    Feb 21, 2003
    1,618
    bump /forums/images/graemlins/rolleyes.gif
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    The style with "hinge" is more popular. Pro-Tools and JD bought use dies that pivot on a mounting bolt similar to those. I would find diagrams of their style bender arms and copy them instead of the styles on those two ebay benders... Or just save your cabbage and buy one. I think there is a thread on POR that has CAD drawings of the PT/JD style bender arms...
  4. RustBuket
    Feb 21, 2003
    1,618
    Alright, so I should go after the one with the pivot. Who sells dies?
  5. RustBuket
    Feb 21, 2003
    1,618
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    www.4wdfactory.com
    call and ask for Greg, tell him Justin sent you
    Depending on bender type will determine the type of die you need. Remeber that when buying a die, it can't bend what the degree it is. Meaning, a 240* die can only bend 180*
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    actually a 240 die can bend more the 180, but you wouldn't be able to get the tube off the die /forums/images/graemlins/whistling.gif
