Tubing Clamps
Discussion in 'The Garage' started by cegusman, Nov 13, 2005.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Anybody know where I get some of these for less than $100 for four. Need them to be 1 3/4' inner [font=&quot]diameter.
    [/font]
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    I don't know. The thickness of that material, and the machining in it, $100/4 sounds not to bad.
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    x2
    Rene
  4. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    do you have a link to where you found them for that price?
    Jesse
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Here is the vendor thread on pirate4x4 "Caution 35%"
    Read the first post
    Here is a link to them on there site
    Mad4wd.com
  6. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    The Poly's are a much better design if it is going to see any stress at all.
  8. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Stupid question, what do you use these for? These look the the compression fittings used to stop pipe leaks.
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I was planing on making a removeable spare tire mount on my cage. I think I am just going to weld the mount straight to the cage and not worry about it being removable.
  10. guido666
    Feb 16, 2005
    788
    Longmont, CO
    So you would weld something to these clamps, like your spare carrier, then bolt them on, so it is removable?
  11. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Yes
    Here are some examples
  12. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Cool, thanx. Are they as strong as just welding it on?
  13. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I don't see a strength problem
  14. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    If you don't need something that look exactly the same, try McMaster-Carr (Mcmaster.com). They are called Shaft Collars.
    Joshua
  15. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Ditto!
    Yes--shaft collars are available in 2 peice types --they are only about 3/4 of an inch wide,but you could weld several together to get the length you need..they look identical to the ones pictured in your post,only skinnier!..they aren't cheap,but you could buy at least 10 of them fot 100 bucks I bet..
    W.W. Grainger sells them too..they also sell a "Key Clamp" type of fittings used to make railings,storage racks,and other things out of regular plumbing pipe that look somewhat like those fittings in your picture,but use allen head set screws to bite into the pipe..they are one peice mallebale fittings,not "split" like the ones you pictured though..they are available in many styles,like "tees","4 way crosses","flange mount",etc..might want to check those out too... :crazy:
  16. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I was looking for those tonight, where do you buy those? I need one to make a mount on my tie rod for my hydro ram assist steering. I've already looked at Mcmaster-carr but they don't come in the inside diameter that i need and they also aren't long enough for my application.
  17. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    you could also try a place called Kar Tek or Car Tek, not sure of the spelling but i think they sell those, try also McKinzie's in Aniheim Ca. they both shoulh have web sites.
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Kartek
    McKenzies
    You could buy this part number 60845K96 from McMaster and cut it in half, but it's still $108/2
  19. rdn2blazer
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    thanks ntsqd.
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I make my own. Not as fancy, no lathe/mill work, just a copule of pieces of tube cut and welded...
