Tubing diameter for rollcages
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudfreak, Dec 24, 2001.
  1. Mudfreak
    Mudfreak 1/2 ton status
    Dec 16, 2000
    116
    NY
    I wanted to ask those of you who have rollcages, what diameter metal tubing you used? Also how it is for passengers to get in and out through the doors to the rear seats?
    88 K5... work in progress
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I use 1 and 3/4 in the Jimmy and 1 and 5/8s in the Firebird. I have the doorbars on the Jimmy so its easy to get in and out. They are about 3-4" above the floor. As for the Firebird they are setup for NHRA specs so if you dont know how to get in and out it can be kinda tricky. Once you learn its really easy though. BTW both vehicles have full cages. The Firebird one is legal for 7.50 1/4 mile, and the Jimmy is a family style cage similar to a safari cage.
    86Jimmy 4"&35"MTRs,87 burb 4"&33"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    I also used 1.75" tubing....works great for me, I personaly don't like the looks of the larger stuff and it takes up more room. Just depends on how ya build it whether it interferes with ingress or not.
    Michael[​IMG]
    <a target="_blank" href=http://www.jmartin.net/parker/goose.htm>www.jmartin.net/parker/goose.htm</a>
  4. Grim-Reaper
    7,385
    Atlanta
    2 inch. I don't have door bars because I got kids gettting in and out. I also didn't do the B pillar shoulder bar for the same reason. Mine is VERY tight to the outside and getting in and out is really no worse than without a full cage. Getting in the back seat may be easier because you can grab the cage to steady yourself and pull yourself in.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    978
    upstate NY(although I cant figure out why)
    I build all mine out of 2"x .120 DOM Just remember you are driving a truck that if you roll it will most likely be at slow speeds. Not at 120mph in a car. I usally only build 6 pt cages for trucks. Make sure you are mounting it to something secure on the floor (not just the floorboards) frame mounting has its advantages and disadvantages. I did a cage for a jimmy a few years ago that I ran the "A pilar" bars down through the speaker holes in the dash pad. made for very little obstrucion..nothing to trip over when getting out
    "There is a fine line between hobby and mental illness"
    Luke
    84 K5
  6. Mudfreak
    Dec 16, 2000
    116
    NY
    Thanks guys, I've got the whole floor out of the blazer, front and rear, so I'm planning on attatching it to the frame. I never really thought about a cage, but reflecting on the number of times I have been on two wheels with the thing, I have re thought the idea.
    Door bars?, I'm not to familiar with what exactly these are? Do they go across the door? I will put the info to good use. Thanks again guys.
  7. Mudfreak
    Dec 16, 2000
    116
    NY
    Calvary, I like the idea of running through the speaker holes, also, what are the adv/disadv of mounting the rollcage to the frame? I thought that would be the only way to be safe and secure in a roll over situation?
  8. BogginChevy
    BogginChevy Registered Member
    May 18, 2001
    14
    Where do you find tubing suited to constructing a roll cage and how do you bend it ect ect.
    Thanks,
    Ryan
  9. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    local steel and aluminum dealer will have it I suggest DOM tubing (drawn over manderal) It's like $25-30 for 20 feet. As forbending it I have a tubebender at work that I can do it find somebody local might do it cheap a couple bends or a freind for some beer sometimes works
    <font color=red>Let me at it I can break it</font color=red>
  10. BogginChevy
    May 18, 2001
    14
    The tube bender you refer to the big hydraulic benders you see at muffler shops right? I have a conduit bender, woudl that work haha j/k :)
  11. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    No a muffler shop bender will kink the pipe you need an actual tube bender. Expect to pay about 500 for one. I ended up paying 750 for mine because I bought both the 1 and 5/8 and the 1 and 3/4 dies.
  12. Mudfreak
    Dec 16, 2000
    116
    NY
    I work at a machine shop , so I can get the materials ordered in. Getting the materials and machining them and welding them in isn't a problem. We actually have an ironworker that does punches and bending and cutting so I'm going to try the bending on that. If anybody has some pics, pleas post em or get me to a link to see them. Thanks1
  13. Cavalry
    Oct 1, 2000
    978
    Mud-
    If you mound directly to the frame it will stiffen up everything in your truck considerably. Your body is isolated by rubber(or poly) If you mount the cage flat to the floor and then gusset down to the frame you have pretty much eliminated your body mounts. Some people use strips of urethane between the floor/gusses/cage but I dont think it flexes enough. I bolt mine to the floor(if the floor is any good plate the hell out of it if it aint) and then put gussets undernieth to the frame with urethane between but no mechanical connection(bolts) that way I still get flex and if the floor fails it has a permanent stop. Its kinda hard to explain so I hope my description is accurate.....oh bending tubing in a ironworker.....umm yikes! give it a try by all means but I would not expect much. To bend tubing the right way one must have both sides of the mandrel take a look at a few tubing benders and you'll see what I mean. Let me know if i confused you any
    Luke
    84 K5
  14. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    most of the time mounting to the frame will just lead to stress cracking the floorpan. unless you hard mount the tub to the frame.
    if you are after rollover protection and not frame strengthening mount the seats and belts to the cage in the tub
  15. Mudfreak
    Dec 16, 2000
    116
    NY
    Cavalry,
    Thanks man , I didn't think of the effects of mounting it to the frame. But now I got some really great ideas, thanks to you. Oh and yeah I see what you mean about the iron worker trying to bend that stuff. LOL ! on to plan B. I came down with this nasty cold, so I won't be able to get to work on it till I feal better, It's really kickin my ass! thanks again for the info.
  16. Michael
    1,576
    Sherman, Texas
    Here is an article from another site that was posted the other day...pretty informative. You might also try a search on this subject....we've talked about it a lot. <a target="_blank" href=http://pirate4x4.com/tech/bendin_tube/index.html>Tube Bending 101</a> I still say HREW (Hot rolled electric welded) tube is fine for most non-racing applications....much cheaper than DOM......but do some research and decide for yourself.
    Michael[​IMG]
  17. AngusF
    AngusF Registered Member
    Nov 18, 2001
    7
    Edmonton, Alberta, Canada
    Man, that is the best site I have ever seen. Thank you so much for posting that. The one thing I haven't seen mentioned here that I think is very important is wall thickness. Almost all sanctioning bodies require .095" wall minimum, and for some sports, .120" is the minimum. If you're in CANADA, you can get 1 3/4" tube suitable for cages from UAP/NAPA, part number UNX 508134. I'm not sure on the exact wall thickness, but I've delivered many a length of that to one of our customers who builds stock cars, which require .095" thickness up here.
  18. Grim-Reaper
    7,385
    Atlanta
    Well these are HEAVY vehicles. in all reality the roll that your most likly going to have is a slow lay over. You can go nuts an build a race car style cage but they are hard to live with as a daily driver. Typicaly most of us build a 6 or 8 point family cage and use .120. Thatr way it acn carry more weight over longer spans so you require les cros bracing. DOM is a bit of over kill for what we do. The Fact is DOM is still a welded seam. It had just had the seam smoothed out durring the manufacture process. Were not going to be having a wreck at 150mph. Tube splitting is not really an issue because our rolls do not deform the cage a great deal if at all.
    Mounting is the big problem. You need to make the mounting points as close to the load bearing braces and cab supports as possible. These vehicles lend themselves very well to the because of the location of the body mounts are right where you want to put the legs. Do not go to the top of the fenders. Run the rear legs all the way to the back corners where you can get close to the tailpan where there is the most strength.
    For the best safety mounting the seat to the cage is a good idea. If for some reason you do have a very violent roll and the bodyt or the cage seperate your still sitting in the cage. You will need to relocate your seat belts to the cage if this is your goal but remember the odds of this type of roll are about like hitting the lottery...pretty slim if you build it right and take care of any rust problems the body has.
    If you do decide to go for a frame mount I would put a captive bushing arangment simular to s spring eye to allow for some movement or make sure you make the frame rigid enough with the cage so as not to get into stress fractures on the floor where the mounts pass through. Becareful you don't over build it. THere is a point where your making it safe and there is a point were you just adding weight and raising the CG. I do feel that a bar in the center or diagonal in the top is a good idea. in a family style cage there is going to be a 4ft by 4ft opening that if you do go over would allow a large object like a rock or tree stump to have entery into the cabin area.
    75 Jimmy, Dollar
    Grim-Reaper
  19. Mudfreak
    Dec 16, 2000
    116
    NY
    Great input, thanks guys, also great site!
    be puttin all the info to use here shortly!
