Tubing end caps
Discussion in 'The Garage' started by BulldogK5, Oct 29, 2005.
  1. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    What are you tubing experts using to cap the ends. I had a welded on cap break off when the bumper fell off the stands while between coats of paint. I am trying to find something round to use. Any idea where to get something, possibly a large bearing or the like?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    take some plate the same thickness or thicker as the wall of the tube, and a hole saw the same od as the tube. now take the piece you cut and weld it in the end of the tube. then plug weld the hole in the center.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Steel freeze caps...............
  4. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    If there is an iron worker near you that dose decorative iron work (ex: gates etc.) they have some pretty nifty steel balls in all diameters. Split them in two and you have really nice caps for tubing.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I've used concave freeze plugs.
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    AA manufacturing sells caps... cheap.
    j
  7. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    I just went and got some Smittybuilt Bumper caps
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I just make my own, cut a small sliver of the tubing you are using, clean up the burrs, with a marker trace the inside dia of the tube onto a peice of flat bar. (now this is what I do->) using the chop saw cut "near" the trace line into an octagon. w/ a belt sander or grinder smooth it out to fit inside the tube and weld it up. if you mildly suck at welding (like me) flap sand the welds smooth.
    i thik freeze plugs look like crap but do the job, and leaving them open is ugly. but thats me.
  9. BulldogK5
    Sep 19, 2002
    4,158
    Brandon, MS
    Thanks for the help everybody.
